Help With College project - Comms Level Shift
K
Kirky
I am working on my college project in which I need to perform a level shift
but am unsure where to start.
The levels are as follows
Unit 1 Unit 2
Logic 0 -0.6v 0v
Logic 1 +5 to +6 2.5 to 4.1v
Unit 2 Unit 1
Logic 0 0 to 0.3v 0 to 0.8v
Logic 1 +0.7v to 3.3v 0.7v(min 0.5mA)
The Supply voltage I am working from is 3.6v.
Any help would be much appreciated.
Jim Thompson
Unit 1 Unit 2
Logic 0 -0.6v 0v
Unit 2 Unit 1
Which ones are SENDING levels, and which are RECEIVING? And provide
some information about source impedances, loading impedances and speed
required.
...Jim Thompson
K
Kirky
Baud Rate is 1200, Unit 1 is a Data Logger which we use at work which has
OPTO coupled comms lines and Unit 2 is a National Semiconducter LMX9820
Blue-Tooth serial port module.
Sorry for being vague but im a novice at the moment. Ive got the datasheet
for the LMX9820 but am unsure as to what the impedances are.
Unit 1(S) to Unit 2(R)
Logic 0 -0.6v 0v
Unit 2(S) to Unit 1(R)
In each case the Sending(S) voltage needs to be converted to the received(R)
voltage.
F
Fred Bloggs
Logic 0 -0.6v 0v
Unit 1(R) Logic 1 makes no sense- you say 0.7V?
F
Fred Bloggs
Kirky said:
sorry my mistake, that should be 2v.
First off, the minimum baud rate on the LMX9820 is 2400 baud-
you might want check for compatibility with your data logger. From your
specs, the data logger appears to be running off Vcc=5V, and the
Bluetooth interface is running off 3.6V. The Bluetooth receive looks to
be CMOS leakage only- it will not load your data logger at all. You will
need to reduce the data logger drive to the LMX9820 UART_RX/ _CTS pins.
The LMX9820 Vih threshold is 0.7 x IOVCC, so that if IOVCC is 3.6V, this
means a minimum input of 2.5V. The Vil is 0.2xIOVCC or 0.72V maximum.
You can run the UART_TX and _RTS pins of the LMX9820 directly to the
data logger. Something like this should work, the diodes should be BAS
Schottky types- they come dual in little SOT packages:
View in a fixed-width font such as Courier.
IOVCC >------+
[10K]
UART_RX <-----+--|>|--[100]--<
LMX9820 SIDE GND--|>|-+
FROM DATA LOGGER
IOVCC >------+
[10K]
UART_CTS <-----+--|>|---[100]--<
GND--|>|-+
IOVCC---|<|-+
UART_TX >------+-[100]--------->
| TO DATA LOGGER
GND--|>|-+
IOVCC---|<|-+
UART_RTS>------+-[100]--------->
GND--|>|-+
K
Kirky
thanks for that, much appriciated.
IOVCC >------+
[10K]
FROM DATA LOGGER
IOVCC >------+
[10K]
GND--|>|-+
IOVCC---|<|-+
| TO DATA LOGGER
GND--|>|-+
IOVCC---|<|-+
GND--|>|-+
