HellasTechn
- Apr 14, 2013
- 1,579
- Joined
- Apr 14, 2013
- Messages
- 1,579
Dear friends. Here i am going to share with you the problem i have.
I need an automatic switch.
I have two GPS receivers which have NMEA output. The output connector is a DB9 Connector.
Pin 2 NMEA data output
Pin 3 NMEA data input
Pin 5 Ground
Now i need to hook both theese GPS receivers to one serial port of a PC in order for the PC to be getting data from GPS-1 and if it fails (Blackout) to automatically switch to GPS-2
I have looked up on the internet to find automatic serial data switch but i only found manual switches.
I thought mabe a 5V relay could do the job but then again how will i drive the relay since the GPS receivers have no "i am on signal" not even a LED indicator.
Any ideas apreciated ! Thank you alot.
Pin 5 Ground
