Help with diode replacement
mksmiffy
Mar 24, 2018
4
Hi I hope someone can help I have to replace the diode D7 in the picture I have tried googling the numbers on the device but I can't find anything I have very limited experience and would really appreciate any help
14,487
welcome to EP :)
I cant read the numbers on the diode ... the pic being upside down doesn't help either
mksmiffy
Mar 24, 2018
4
If you zoom in to the picture c528 then 9258 ?
Thank you davenn
73's de Edd
Aug 21, 2015
3,730
Are you just grasping for straws . . . . . what is the Vf being read across it with a DVM in diode test mode . . . . with it possibly reading ~200 mv, unless you have a shorted junction.
mksmiffy
Mar 24, 2018
4
Sorry like I said I have limited experience the diode is open circuit
Yes I probably am grasping at straws just hoping that someone would know what diode this is so I could replace it.
I never intended to annoy just I have no clue and I could do with some help.
WHONOES
May 20, 2017
1,242
Does the PCB have a manufacturers name and part number on it. If so it may be possible to get some info on the board such as a schematic or Bill of Materials (BOM) which may help.
AnalogKid
Jun 10, 2015
3,058
That looks like the ON Semiconductor logo. 9258 probably is the date code.
ak
mksmiffy
Mar 24, 2018
4
Thank you all it's a Chinese soldering iron control board so no diagrams I can't even find a manufacturer.
I will remove it from the board to get a better picture as it has a symbol on it but not ON
