help with eprom programmer power supply.
vari21
Apr 15, 2020
16
Hi, excuse me if i ve posted that in the wrong place.
I ve uploaded a shematic of an eprom programmer power supply that i want to build ,as you can see this power supply uses two relays, relay1 in green ,and relay2 in red.the guy who build this power supply says that the two relays have to be coil relay 24v 4rt with 1300ohms of resistance.my question can i put any other relay than the one given cause i could nt find on ebay
the same one or maybe can someone help me with that thanks very much.
this is the whole project ,sorry t s in french.
http://electroremy.free.fr/elec-mo-gl27.html
bertus
3,882
Did you try google translate?
https://translate.google.com/transl...=http://electroremy.free.fr/elec-mo-gl27.html
It is not perfect, but will give you a better idea.
For the information of the others is here the partlist from the given page:
3. La liste des composants
Carte écriture :
1 * Support tulipe 28 broches
2 * CD4040
* CD4049
* Condensateur 100 nf - 400 V
1 * Résistance 8,2 KOhms - 1/4 W
8 * Résistance 470 Ohms - 1/4 W
Carte lecture :
2 * CD4040
* CD4049
* CD4512
Carte sélection :
2 * Inverseur unipolaire à levier
2 * Inverseur bipolaire à levier
Carte alimentation :
TR1 : Transformateur 220V//24V 500 mA
B1 : Pont de diodes 50V - 1A
I1 : Double interrupteur 220V - 1.5A
D1 = D2 = D3 = D4 = D5 = D6 = D7 = D8 : 1N4001
DZ1 : Diode zener 8,2V - 1/4WD1
REG1 = REG2 = LM317
T1 : 2N2222
R1 : 220 Ohms - 1/4W
R2 : 220 Ohms - 1/4W
R3 : 470 Ohms - 1/4W
R4 : 10 KOhms - 1/4W
R5 : 1,5 KOhms - 1/4W
R6 : 1,5 KOhms - 1/4W
R6' : 1,5 KOhms - 1/4W
R7 : 1,5 KOhms - 1/4W
R7' : 2,2 KOhms - 1/4W
R8 : 22 Ohms - 1/4W
R9 : 47 Ohms - 1/4W
P1 = P2 = P3 = P4 : 1 KOhms - Pour circuit imprimé (debout)
C1 : 47 µf - 35V - Chimique radial
C2 : 1000 µf - 35V - Chimique radial
C3 : 4700 µf - 35V - Chimique radial
C4 : 470 µf - 35V - Chimique radial
C5 = C6 = C7 = C8 : 100 nf - 400V
RL1 = RL2 : Relais 24V - Bobine 1300 Ohms - 4RT
Bertus
vari21
Apr 15, 2020
16
Hi bertus, i can read understand french no problem.
what relay do you recomand to put in there ,can you direct me to a link wich sells the right relay ,im confused and i dont know which one i buy thanks again.
