HELP with flash quenching IGBT/MOSFET
K
KD
Hey guys,
Need help in finding an appropriate MOSFET/IGBT to pulse my hi energy flash
lamp.
I currently have a 100Ws rated flash lamp running at 330V / 1620uF (88Ws)
I'm want to do pre-flash followed by the main flash so I decided to use a
MOSFET to drive the trigger transformer and pulse shapping directly.
http://optoelectronics.perkinelmer.com/content/ApplicationNotes/flashlightingappnote.pdf
(page 3)
I've been using a MOSFET with ratings of 500V and 48A continuous/192A
pulsed. However, these MOSFETS have been dying on me after around 100
flashes... I did a current test flash pulse on them and found that it drew
about 70A peak with a pulse duration of around 15ms.
Is my MOSFET rated correctly???
If not, what rated MOSFET should I use??
What's the difference between an IGBT and MOSFET? I also used an IGBT (rated
for 85A continuous ) in place of the MOSFET and it failed to trigger with a
logic signal directly from the microcontroller (5V). I then tried to
manually trigger the IGBT with a 7V source and it only flashed once -
assumed I blew the IGBT... what am I doing wrong?
thanks...
Phil Allison
"KD"
flash lamp.
(page 3)
** Is that an IXFK48N50 at circa $75 each ??
** A bigger one.
** Oh dear.........
I also used an IGBT (rated for 85A continuous ) in place of the MOSFET and
it failed to trigger with a logic signal directly from the microcontroller
(5V).
** Oh deary me ........
I then tried to manually trigger the IGBT with a 7V source and it only
flashed once - assumed I blew the IGBT... what am I doing wrong?
** Everything.
( This reminds me of the story of Microfarad and Millihenry. )
.......... Phil
Phil Allison
"KD"
** Stop SHOUTING !!!
Plan on blowing a lot of fets up.
Or electrocuting yourself.
Or both.
......... Phil
