Help with FPC contacts
Leon mcbride
Aug 31, 2015
5
Hi all I'm new here and after some help!
Been looking everywhere I cant find a "FPC connector" More specificly a "FF22D series 0.3mm pitch, 57way, 2 Row, SMT gold plated contact"
Can anyone please help with any information, would go a long way
Leon
dorke
Jun 20, 2015
2,342
Old steve,
yep, googled it.
you beat me to it,a visit to the wc room :)
Old Steve
Jul 23, 2015
734
Old steve,
yep, googled it.
I wish everything was that easy to find. It's even in Leon's country.
It's an old pdf, though, so hopefully they still stock them.
Leon mcbride
Aug 31, 2015
5
Hi sorry to burst anyone's bubble But I'd already googled it and I new about the PDF file.. But I'm after buying replacements
On researching The PDF was made in 2008 so it's old now.. But would anyone no of any knocking around? I can't find anyone who stocks them
Thanks guys
Old Steve
Jul 23, 2015
734
Thanks guys
No bubbles burst here.
Did you contact 'servoconnectors' directly and ask them, just in case?
JSF appear worth a look, too, as dorke says.
Old Steve
Jul 23, 2015
734
Thanks old Steve I'll try contacting them
You never know your luck.
Also, FF22D might just be a proprietary part number. Searching by FFC, pitch and number of pins might give you a better chance.
I assume this is an FFC connector, which connects to an FPC?
I've been looking at a couple of other sources, Digikey, Mouser, RS etc, even eBay, just in case.
(Ignore my Google comment earlier - when I saw how quickly a result came up it appeared that you hadn't done much searching.)
Leon mcbride
Aug 31, 2015
5
I'll try that too thanks.. I had already tried RS and I went for FF22 because everything married up, regards number of contacts, pitch and terminat type. But when I got them and placed them on bored they were still not wide enough if that makes sense? Between the front and then back soldering points.. So I thought I'd try and keep to the same product code..
And no harm done old Steve I understood Where you where coming from I should of notied that I had already searched when I post the thread..
Old Steve
Jul 23, 2015
734
No worries, and when I get a chance I'll have a bit more of a look and see if I can find them anywhere. You can bet your @#$% there are some out there somewhere, it's just a matter of finding them.
