Help with Kantech Acces Control
Shkumma
i have a problem with kantech KT-300 we have 12 of them some of them are
providing events of Time and attendance some of them not,we have configure
all of them same and we try with different firmware but still the same
problem...
Thnx in advandce for your help...
Guest
"Shkumma" a écrit dans le message de groupe de discussion :
[email protected]...
problem...
Hi, first with what software are you driving it?
are they online (status tab) ??
what type of connection are you using ? usb or serail to rs 485??
what type of wiring are you using for the communication bus?
and finally are you sure that you have the good serial number in the
programing of the controler?
Shkumma
responding to
http://www.secure-gear.com/security-physical/Help-with-Kantech-Acces-Control-59213-.htm
configure
problem...
Hi,thnx for your reply.
We are using entrapas corporate editions v.3.16
they are online because we are using access control for doors and we
change all the time access to doors.
connections is through RS-485 its maby 5 Meter length to PC,
Bus is with Burglary alarm cable we use that but is working for some of
them OK..
And I'm sure cos they are online i can reset them and change access but
isn't providing time and attendance events
its like this
access granted door open card xx person xx
when its OK is like this
time and attendance card xx person xx
so from here then we can make one report..
thnx again...
Guest
responding to
configure
problem...
them OK..
its like this
thnx again...
Yet you dont see any event on some controler??
if you reset those controler manually, do you see any event from those
controler?
in the controler operation tab of the workstation do you see all controler
with the same icon?
in the status tab on the on the communication section do you all the
controler a online?
how many controler do you have connected? are they on different loops or on
only one?
H
Hakma
Sounds like a configuration isssue, is it possible that those doors that are
not displaying the the T&A status are not defined as T&A doors ?
Shkumma
responding to
Shkumma wrote:
Petem,
I see only access events but not T&A on some controllers,
Yeah all of them in operations are with same icon,
there are 12 of them in same loop,
i have made a manually reset and hard reset no results
they are with same green tick icon all of them online,
i think is something else not configurations because we put different
controller from another LOOP with same configurations we change just
address and everything was working OK With T&A....
Thnx in advandce,
them OK..
its like this
thnx again...
controler?
controler
with the same icon?
controler a online?
on
only one?
