Glad to hear that it's working well. And that explains the puzzling voltage from the open-drain output.Okay so ive figured out my i was using a 9v battery that was almost out of juice and hence why i was getting a lower output voltage than the assumed 9v supply. Put a fresh 9v battery in and it seems to give me a full 9v's output. Using a relay with the freewheel diode in place i can successfully control my 12v motor!
That's understandable. Is it possible to run the 12V wires back from the battery with the motor / relay wires? Just a thought.A 12v supply would certainly simplify the whole design but i wanted to keep the enclosure containing the receiver as small as possible hence the 9v battery.
So would I as aboveThat's understandable. Is it possible to run the 12V wires back from the battery with the motor / relay wires? Just a thought.
