Help with ttl power-on reset pulse
Titus
Aug 19, 2016
4
Untitled-2.png Hello everybody, I need a power-on reset circuit for ttl 5v levels.
It needs to send a 500 ms high (+5v) pulse when initially powered on and then stay low
Thank you in advance!
Titus
Aug 19, 2016
4
I've tried many examples that I found online but none worked as intended
Tried with resistors and caps, also tried one with a diode but still can't make it work.
On power on, it randomly latches but I need to set it to a known state at power on / startup
You need a capacitor to ground and a pull up resistor with a time constant of about 0.5 seconds.
Be aware that this pulse will have a slow rise time and you should probably apply this to an input with a Schmitt trigger.
Alternatively you can square it up with a standalone Schmitt trigger (typically an inverter as well)
Oh, it's a good idea not to reply to your own question before anyone else because it appears as if the question has been answered (at least for those of us who look for threads that nobody has replied to)
Titus
Aug 19, 2016
4
Hi Steve, thank you for your answer.
I ended up using a 555 for the reset pulse, I know is a little over the top and could be done in a more simple way without using a 555, but it seems to work very good for me.
This is like a programmer that is not very knowledgeable and uses 100 lines of code to execute a certain task when the same task could be done with 20 lines if you really know what you are doing.
I've used the remaining gates on the IC to be able to have an external source for the reset as well as the pulse from the 555 and the last gate as an inverter.
The timing with this circuit is about 110 ms
AnalogKid
Jun 10, 2015
3,056
Here is the same circuit without the 555. The added resistor R3 adds hysteresis to the R-C input to eliminate possible noise bursts at the output. It does not affect logic action caused by the pin 11 input.
ak
  • POR-1-c.pdf
