Help with using shift register to expand uC output
max_torch
Feb 9, 2014
111
I am just practicing how to use shift registers to expand a microcontroller's output. So far I'm only practicing using assembler language, I haven't yet dabbled in using C or BASIC with microcontrollers.
Here is a schematic I made:
The shift registers im using is the 4094 and the microcontroller is PIC16F84A, with oscillator set to 4MHz.
I wrote a program that will count from 0 to 29, wherein the ones place is at the bottom, and then display 1 in all the segments after that for a brief duration, then loop back to the start.
It sort of works..
My problem is that in some frames, the output doesn't come out right, but when the program loops back to the start and reaches that same frame it then comes out okay but then other frames don't come out right.
Basically, everytime it runs it seems like on some frames the output randomly don't display the numbers properly and there is no way to predict on which frames the error will occur.
Please help me find what is wrong with my program, or circuit.
Here is the source code:
include <p16f84a.inc>
__CONFIG _CP_OFF & _WDT_OFF & _XT_OSC & _PWRTE_ON
cblock 0x20
d1
d2
d3
temp
digit
placer
endc
CONFIG bsf STATUS, RP0
clrf PORTB
bcf STATUS, RP0
clrf PORTB
movlw d'200'
movwf temp
Flush bsf PORTB, 1
bcf PORTB, 1
decfsz temp, f
goto Flush
START bsf PORTB, 3 ;Set OE
movlw d'7'
movwf placer ;placer starts at 7
movfw placer
movwf digit
call ZERO
decfsz digit, f
goto $-2
bsf PORTB, 2
bcf PORTB, 2
call DELAY
decf placer ;placer is now 6
movfw placer
movwf digit
call ONE
call ONES
movfw placer
movwf digit
call TWO
call ONES
movfw placer
movwf digit
call THREE
call ONES
movfw placer
movwf digit
call FOUR
call ONES
movfw placer
movwf digit
call FIVE
call ONES
movfw placer
movwf digit
call SIX
call ONES
movfw placer
movwf digit
call SEVEN
call ONES
movfw placer
movwf digit
call EIGHT
call ONES
movfw placer
movwf digit
call NINE
call ONES
decf placer ;placer is now 5
movfw placer
movwf digit
call ZERO
call TENS
movfw placer
movwf digit
call ONE
call TENS
movfw placer
movwf digit
call TWO
call TENS
movfw placer
movwf digit
call THREE
call TENS
movfw placer
movwf digit
call FOUR
call TENS
movfw placer
movwf digit
call FIVE
call TENS
movfw placer
movwf digit
call SIX
call TENS
movfw placer
movwf digit
call SEVEN
call TENS
movfw placer
movwf digit
call EIGHT
call TENS
movfw placer
movwf digit
call NINE
call TENS
movfw placer
movwf digit
call ZERO
call TWENTY
movfw placer
movwf digit
call ONE
call TWENTY
movfw placer
movwf digit
call TWO
call TWENTY
movfw placer
movwf digit
call THREE
call TWENTY
movfw placer
movwf digit
call FOUR
call TWENTY
movfw placer
movwf digit
call FIVE
call TWENTY
movfw placer
movwf digit
call SIX
call TWENTY
movfw placer
movwf digit
call SEVEN
call TWENTY
movfw placer
movwf digit
call EIGHT
call TWENTY
movfw placer
movwf digit
call NINE
call TWENTY
call ENDER
goto START
ONES call ZERO
decfsz digit, f
goto $-2
bsf PORTB, 2
bcf PORTB, 2
call DELAY
return
TENS call ONE
call ZERO
decfsz digit, f
goto $-2
bsf PORTB, 2
bcf PORTB, 2
call DELAY
return
TWENTY call TWO
call ZERO
decfsz digit, f
goto $-2
bsf PORTB, 2
bcf PORTB, 2
call DELAY
return
ENDER call ONE
call ONE
call ONE
call ONE
call ONE
call ONE
call ONE
bsf PORTB, 2
bcf PORTB, 2
call DELAYLONG
goto START
;;;;;;Digits Subroutines;;;;;;;;;;;
ZERO bcf PORTB, 0
movlw d'2'
movwf temp
bsf PORTB, 1
bcf PORTB, 1
decfsz temp, f
goto $-3
bsf PORTB, 0
movlw d'6'
movwf temp
bsf PORTB, 1
bcf PORTB, 1
decfsz temp, f
goto $-3
return
ONE bcf PORTB, 0
movlw d'5'
movwf temp
bsf PORTB, 1
bcf PORTB, 1
decfsz temp, f
goto $-3
bsf PORTB, 0
movlw d'2'
movwf temp
bsf PORTB, 1
bcf PORTB, 1
decfsz temp, f
goto $-3
bcf PORTB, 0
bsf PORTB, 1
bcf PORTB, 1
return
TWO bcf PORTB, 0
bsf PORTB, 1
bcf PORTB, 1
bsf PORTB, 0
bsf PORTB, 1
bcf PORTB, 1
bcf PORTB, 0
bsf PORTB, 1
bcf PORTB, 1
bsf PORTB, 0
movlw d'2'
movwf temp
bsf PORTB, 1
bcf PORTB, 1
decfsz temp, f
goto $-3
bcf PORTB, 0
bsf PORTB, 1
bcf PORTB, 1
bsf PORTB, 0
movlw d'2'
movwf temp
bsf PORTB, 1
bcf PORTB, 1
decfsz temp, f
goto $-3
return
THREE bcf PORTB, 0
bsf PORTB, 1
bcf PORTB, 1
bsf PORTB, 0
bsf PORTB, 1
bcf PORTB, 1
bcf PORTB, 0
movlw d'2'
movwf temp
bsf PORTB, 1
bcf PORTB, 1
decfsz temp, f
goto $-3
bsf PORTB, 0
movlw d'4'
movwf temp
bsf PORTB, 1
bcf PORTB, 1
decfsz temp, f
goto $-3
return
FOUR bcf PORTB, 0
bsf PORTB, 1
bcf PORTB, 1
bsf PORTB, 0
movlw d'2'
movwf temp
bsf PORTB, 1
bcf PORTB, 1
decfsz temp, f
goto $-3
bcf PORTB, 0
movlw d'2'
movwf temp
bsf PORTB, 1
bcf PORTB, 1
decfsz temp, f
goto $-3
bsf PORTB, 0
movlw d'2'
movwf temp
bsf PORTB, 1
bcf PORTB, 1
decfsz temp, f
goto $-3
bcf PORTB, 0
bsf PORTB, 1
bcf PORTB, 1
return
FIVE bcf PORTB, 0
bsf PORTB, 1
bcf PORTB, 1
bsf PORTB, 0
movlw d'2'
movwf temp
bsf PORTB, 1
bcf PORTB, 1
decfsz temp, f
goto $-3
bcf PORTB, 0
bsf PORTB, 1
bcf PORTB, 1
bsf PORTB, 0
movlw d'2'
movwf temp
bsf PORTB, 1
bcf PORTB, 1
decfsz temp, f
goto $-3
bcf PORTB, 0
bsf PORTB, 1
bcf PORTB, 1
bsf PORTB, 0
bsf PORTB, 1
bcf PORTB, 1
return
SIX bcf PORTB, 0
bsf PORTB, 1
bcf PORTB, 1
bsf PORTB, 0
movlw d'5'
movwf temp
bsf PORTB, 1
bcf PORTB, 1
decfsz temp, f
goto $-3
bcf PORTB, 0
bsf PORTB, 1
bcf PORTB, 1
bsf PORTB, 0
bsf PORTB, 1
bcf PORTB, 1
return
SEVEN bcf PORTB, 0
movlw d'5'
movwf temp
bsf PORTB, 1
bcf PORTB, 1
decfsz temp, f
goto $-3
bsf PORTB, 0
movlw d'3'
movwf temp
bsf PORTB, 1
bcf PORTB, 1
decfsz temp, f
goto $-3
return
EIGHT bcf PORTB, 0
bsf PORTB, 1
bcf PORTB, 1
bsf PORTB, 0
movlw d'7'
movwf temp
bsf PORTB, 1
bcf PORTB, 1
decfsz temp, f
goto $-3
return
NINE bcf PORTB, 0
bsf PORTB, 1
bcf PORTB, 1
bsf PORTB, 0
movlw d'2'
movwf temp
bsf PORTB, 1
bcf PORTB, 1
decfsz temp, f
goto $-3
bcf PORTB, 0
bsf PORTB, 1
bcf PORTB, 1
bsf PORTB, 0
movlw d'4'
movwf temp
bsf PORTB, 1
bcf PORTB, 1
decfsz temp, f
goto $-3
return
DELAY movlw d'2'
movwf d1
movlw d'24'
movwf d2
movlw d'167'
movwf d3
LOOP decfsz d3, f
goto LOOP
decfsz d2,f
goto LOOP
decfsz d1,f
goto LOOP
return
DELAYLONG movlw d'18'
movwf d1
movlw d'24'
movwf d2
movlw d'167'
movwf d3
LOOP2 decfsz d3, f
goto LOOP2
decfsz d2,f
goto LOOP2
decfsz d1,f
goto LOOP2
return
END
  • readfromregoutput - Copy.txt
Old Steve
Jul 23, 2015
734
Aaaaargh, you're kidding!
max_torch, first a point I must raise - you have to use code tags when posting code. The above looks terrible. The length doesn't help - it's virtually unreadable.
You'll find the code tags on the toolbar above the edit window. Hover your mouse over the fourth item from the right and an "Insert..." tooltip will appear. Click on that button and select "Code", then paste your code into the window that appears.
It's also a good idea to get rid of all superfluous spacing, particularly when posting a long example as you have. You don't need all of those spaces between lines - it makes it much harder to read.
Correct formatting would help, too, with the instructions indented, (I'll bet you're getting lots of assembler errors), and the subroutine labels on separate lines.
Then someone might take the time to look at it, but even then, it's just plain too long.
Also, mention which assembler and the IDE you're using, if any, when you post.
You should also include liberal comments, so someone reading your code can tell what's going on at a particular point.
For me, this is just too long and messy to contemplate. You could correct your post - it's not too late. (Then I'll edit this reply to reflect your 'repaired' post.)
Edit: It's best to fully format your code before pasting it into the "code" window, too. It's much harder to format there, since 'tab' can't be used to indent.
max_torch
Feb 9, 2014
111
I could no longer edit the OP. Please consider this the new OP. I hope the code now would be 'readable'
shiftreg-png.22377
It sort of works..
Basically, everytime it runs it seems like on some frames the output randomly doesn't display the numbers properly and there is no way to predict on which frames the error will occur.
When I built the source code there was no error or warning. All the labels are in the first column and all assembler instructions are in the second indent.
The IDE I'm using is MPLAB.
The source code is attached in a zip file as a .asm, because if I try to copy it to notepad, or to here using the code tag the indentations get screwed up.
  • send.zip
max_torch
Feb 9, 2014
111
Also, I'm using Proteus VSM to simulate.
Here is the .dsn file of the simulation:
  • dsn.zip
Old Steve
Jul 23, 2015
734
shiftreg-png.22377
It sort of works..
I don't have time to go over that much code searching for your errors, it would take me hours. I don't usually write in assembly. I write in C or PICBasic, because assembly is too slow and difficult to debug. I can help with simple, short assembly snippets, but not this megalith.
And please don't PM me again personally asking me to check it.
The best I can suggest is that you run it in the MPLAB simulator, or wait for someone more fluent in PIC assembly language to help out.
wrighty
Aug 1, 2009
10
Your code would be much simpler if you had 2 loops.
Inner loop does segment data and outer loop takes in data for segment from a table in memory.
Colin Mitchell
Aug 31, 2014
1,416
Start by simplifying everything
for instance
d'18'
is .18
a file or register in a delay will 255 or 256 times without having to load it at the start.
This saves 2 lines of code.
Use a table. This will simplify the listing.
See talkingelectronics.com website for .asm guides and a complete list of subroutines
CDRIVE
May 8, 2012
4,960
Reading your stuff is always fun but it sometimes (most times) requires extensive training in the art of ciphers and deciphering. I'm not an ASM wiz but this code snippet was easy. Change d'18' (="d"ecimal 18) to .18.
for instance
d'18'
is .18
But then we move along to Molasses Swamp and get bogged down repeatedly reading your next sentence. Are there words missing?? "Will" what?
Does it matter if it's Shaker, Stickley, Queen Ann, other? Sorry, I couldn't help myself! :p
Ah, while instructive words may always seem to be missing in your posts this plug is something that's never forgotten. Hey, just bust'n your 'OO'. I woke up this morning and thought I was Martin. :D We do need a 'OO' busting smiley though!
Cheers,
Chris
