I picked up a pair of Tapco S5 active monitors. The seller made it clear one had a fault.
Fault is that when one speaker is switched on it buzzes loudly and the larger speaker can be seen to pull inwards.
Video showing the fault can be viewed here:-
I am at a basic level with electronics. I can solder, and have a meter if required. My usual plan of attack is visual and being a board jockey.
I removed the electronics side and thought I had found the fault. Looked very like I had a leaky capacitor as there was a build up of fluffy crud around the base of one. Replaced this and it's still the same.
Swapped the full panel from the good speaker and no buzzing, however, I am pretty sure the tweeter is blown as sound was very dull and zero sound compared to the known good speaker.
Transformers on both speakers work fine.
So.....I know the problem is on this board but where? At this point I am out of my depth.
Could I ask you guys what you reckon the most likely part to fail may be?
The Bridge Rectifier is part no KBL406
Looks to be an amplifier chip for the low frequency and high frequency sides. Same part no for both is LM3886T.
