Hi speed relay solid state
Donald Hadley
Has anyone seen a solid state relay that will switch a signal of 2-3
MHz at speeds of up to 1KHz?
If not, what would be the highest practical limit for this type of
device?
The intent is to produce a crude modulated signal.
Continuous duty rating would need to be about 30 watts.
Thank you for any pointers.
Don Hadley
Rene Tschaggelar
device?
You're basically looking at a mixer.
You could try to build one yourself
with a set of power shottky diodes.
Make sure to consider what happens
with the reflected power.
Rene
F
Fred Bloggs
device?
The limitation is not the speed, it is the 45dBm power level. You will
have to go custom or shell out big bucks for a niche market switch. From
your description, it is understood that you have a single channel that
is turned on and off- sounds pretty simple.
John Larkin
device?
Don Hadley
Sounds pretty easy. Look at CEL.COM for the NEC ssr's. At your speeds,
expect some asymmetry of on/off switch times and a bit of off-state
feedthrough from capacitance, but "crude modulated" won't be hard.
John
