Jasie
- Jan 1, 1970
- 0
I have an inkling of electrical knowledge, but I really need a lot of help
here.
I have 10x12v high current Batteries in serial. I want to add some ultra
capacitors (only 2.5v / 450F / 180A) say, 20 to the circuit.
I then want to be able to limit the speed of charge to the capacitors from
the batteries variably, (slow drain from bats results in more overall
power).
These are all powering a motor. The initial start surge to be taken up by
the caps followed by a constant drain on the batteries. The motor also has
regen braking, so how do I dump the brake power back into the caps (up to
max capacity) and then use the remainder for recharging the batteries?
We're talking high amps here of around 40 kw to 150kw burst (accelerating)
max.
I guess this is easy for a knowledgeable person in D.C.
Thanks a lot in advance.
Jason.
here.
power).
max.
Jason.
