High density drivers?
dave94024
I have an application that requires Totem pole type drivers to deliver
~1A for <1us. I need a lot of these setup in essentially a long chain
of H bridges into non-inductive loads. There is nearly no duty cycle
to speak of, each driver energized every few seconds or less (only
while in use).
I can of course do this with discretes but I have to make it as small
as practicable. I'll be driving these drivers with 5v logic from a
microcontroller. I need nearly a 100 of these high/low drivers and
have looked at various solutions. This is not for a long-term product
and I'm willing to exceed the rating of the parts in question (as long
as they'll survive for a few months of sporadic use, figure 1000
activations tops (for each driver)).
Any thoughts or suggestions?
Dave.
John Larkin
while in use).
Dave.
How much output voltage? There are some SO-8 (or dip8) dual mosfet
gate drivers that might work.
What's the application?
John
dave94024
John- Hide quoted text -
The loads are 5-6 ohms each and there's one set of drivers on either
side, so we need whatever voltage is required to drive a little over 1
amp through the load (accounting for the RdsOn of the gates or the
diode drops of transistors (if we're using them)).
I was using some dual Mosfets up till now without any problems (in an
even smaller package actually), but I'm looking for something denser
if possible.
Dave.
