high/ low level indicator
smoknjoe44
Oct 11, 2005
9
Will a water level indicator work with anything other than water.  What I want to do is build a circuit that will give me a good idea of how much grain is in some feed bins that you would find on a farm.  I'm tired of climbing up them to check how much grain is in them and thought I might give this a try.  I'm also new to electronics...Thanks.
audioguru2
Apr 6, 2004
12,022
Please post the schematic of a water level indicator or a link to its project so we can see if it depends on the electrical resistance of the water or some other way that can't sense your grain.
audioguru2
Apr 6, 2004
12,022
The Water Activated Alarm uses the fairly low resistance of water between its probes to work. It would also sense coins very well.
Unless your grain to be sensed is soaking wet, it won't detect it.
Maybe you could use an LED on one side of the bin shining on a light detector on the other side, if the bin is dark inside. When the grain's level in the bin drops low enough so that it unblocks the light, then the alarm sounds.
If the grain isn't too dusty then the LED and light detector can be mounted side-by-side and shining on and reflecting off a mirror on the other side.
ante1
Jan 24, 2004
4,136
Hi Joe,
Isn’t it possible to use simple mechanical pressure pads on the inside of the silo wall at the desired height/s?
audioguru2
Apr 6, 2004
12,022
I think the mice in there would push on the pads. ;D
ante1
Jan 24, 2004
4,136
So.. there are mice inside the feed bins, I get it it’s a snake farm then! ;D
audioguru2
Apr 6, 2004
12,022
I don't know if grain farmers put cats or snakes in the bins to eat the mice. What would they put to eat the cats or snakes? Then what would they put to eat .....
Shahriar
Mar 18, 2004
451
Dear smoknjoe44
Maybe using an InfraRed receiver and transmitter will do the job. when there is enogh Bin, the receiver does not receive anything and the LED will turn On.
HTH - Shahriar
