high pulse delay circuit with transistor
Rggmiranda
Mar 1, 2014
6
Hi everyone, i need to turn on something if a signal is HIGH for a certain period of time, and turn it off afterwards, basically, if the input is HIGH for 10 seconds it triggers and the transistor or relay in the output closes, after the signal goes LOW it shuts down, I've been trying with caps and resistors charge delay but it gets tricky with the discharge, im not sure that is the correct way, any ideas? Thanks
Wesley Weaver
Apr 15, 2015
6
you'd have to post what you're working with already for us to see what you're talking about
Rggmiranda
Mar 1, 2014
6
That would be a brief example, i would like to charge the cap until it reaches the minimum voltage to drive the transistor, and by doing that generwting the delay
