high-resistance wire 40kOhm per meter
Michael Koch
Tim,
Carbon-core "ignition wire" is about 5K ohms per foot.
yes, but the diameter is too big. I want to build several 3-axis sensors.
Michael
Michael Koch
Joerg,
Can't you make it from small snippets of regular very thin wire with,
say, a 0201 size or smaller 402 ohm resistor every centimeter and slide
it all into thin tubing?
That's a lot of work. At least the first meter from the sensor should
have high resistance. That means I need 4 meter wire for a 3-axis
sensor. And my idea was to have several 3-axis sensors mounted on a wood
frame, so that field homogeneity can be measured simultaneously at all
sensors. For example 3 x 3 x 3 = 27 sensors in a 1m^3 cube, each sensor
is 3-axis, --> 81 sensors total. That's only possible if cheap
high-resistance wire is available.
Michael
Joerg,
Michael
wet string?
Rich Grise
the NIST E-field detector is built with high-resistance wire, about
40kOhm per meter. It's described here:
http://scott-inc.com/html/nist.htm
Does anybody know a source for this wire?
You can get 0.0031" OD nichrome wire at McMaster-Carr:
http://www.mcmaster.com/#catalog/115/3675
But you'll have to figure out the resistance per foot on your own.
Thinner wire is probably available - I just happened to know MMC has
it off the top of my head.
Good Luck!
Rich
Michael Koch
Joerg,
Michael, this just dawned on me, you might want to call Isabellenhuette
in Dillenburg, Germany (hey, I was in that town last March ...) and ask
about their ISA-Ohm wire. Not quite the 40k but almost 17k for the
really thin stuff:
That's very interesting, I think it's close enough to 40kOhm/m.
Thanks!
Michael
W
whit3rd
40kOhm per meter. It's described here:http://scott-inc.com/html/nist.htm
The easiest source for resistance wire is thermocouple alloys (like
Constantan, for type J thermocouples, which was originally
a low tempco resistor wire). My tables show 56 gage as the finest
and that only has a tenth the resistance you want. It gets
brittle (and becomes a fuse more than a wire) if you try to
get thinner wire.
Some HV resistors are made with a buffer solution in vinyl tubing,
you could get a roll of capillary tubing and mix up your own
fill liquid.
