High resolution PWM for fake DACs
Phil Hobbs
Hi, all,
I've been working on an automatically-tweaked noise canceller design
with my trusty code and layout Sherpas-in-training (my son and my
younger daughter).
I need about 10 slow but high resolution DAC outputs for the tweaks, and
I was thinking about using PWMs run from the LPC1769 processor for at
least some of them.
I can close the loop on them with an on-board delta-sigma ADC (AD7708 or
maybe AD7718) for an occasional sanity check.
I'd need some level shifting and stuff to make the required voltage
ranges in any case, so the complexity isn't that different from using an
actual DAC, and it would be a lot cheaper.
They're going into low level signal circuitry, is the only real issue,
so things like the noise on the logic supply will need dealing with,
e.g. by running it through a 74HCT04 powered from a clean 5V rail.
Suggestions? Pitfalls to beware of?
Cheers
Phil Hobbs
Dr Philip C D Hobbs
Principal Consultant
ElectroOptical Innovations LLC
Optics, Electro-optics, Photonics, Analog Electronics
160 North State Road #203
Briarcliff Manor NY 10510 USA
+1 845 480 2058
hobbs at electrooptical dot net
http://electrooptical.net
U
Uwe Hercksen
least some of them.
the problem of high resolution PWM is the necessary long period time and
the low pass filter for very low frequency.
I saw a different aproach in a Fluke calibrator, they used two PWMs
together, one for the first 4 decades and one for the last decade. But
this requires two resistors with very precise values.
Bye
Spehro Pefhany
Bye
Why very precise? If you're only looking for 3.3 bits more, the ratio
match can be pretty sloppy.
Best regards,
Spehro Pefhany
U
Uwe Hercksen
you should not compare to the least significant digit of the 4 decades,
you should compare to the most significant digit. The ratio is 9999/1
not 10/1.
Bye
Spehro Pefhany
not 10/1.
Bye
You're talking about a voltage divider with a ratio of, say 1000:1
Say 1M and 1K, with each end effectively connected to a voltage
between 0V and Vref (depending on the duty cycle of each).
(ignoring the switch resistances!)
So if the 1M is actually 1.05M or 0.95M, what will the effect on the
ouput voltage be? Best case is when both PWMs switch at the same time-
the values of the resistors don't matter at all. Worst case is when
the two voltage are opposing each other, say 0V on the 1K and +Vref on
the 1M. The voltage on the output node will be Vref * 1K/(1M + 1K) =
0.000999 * Vref (just under 1 LSB in the other PWM).
If the 1M is actually 1.05M, the voltage will be 1K/(1.05M + 1K)* Vref
= 0.0009515 * Vref
The error is ~-0.005%, or less than 0.5 LSB of the composite converter
(one LSB is 1 part in 10,000 of the full scale voltage).
Assuming one uses good resistors, the bigger error will probably come
from the switch resistance associated with the lower value resistor.
Best regards,
Spehro Pefhany
