Phil in Melbourne
- Jan 1, 1970
- 0
So I would have thought that this would be a simple problem but the more
information I get the more I get confused......
I want to PWM a whole lot of LEDs. The current consumption of the bank of
LEDs is in the order of 15 Amps, at 12V.
For reasons I won't go into, my only option is to use a high side mosfet.
I have chosen an N-channel MOSFET (IRL3803) mainly because of its huge
current capability and very low on resistance of 7 milli ohms.
I am hoping to use PWM at a reasonably high frequency, say 20khz or higher,
and I want to use an efficient MOSFET driver IC that is designed for the
job.
I understand that to switch an N channel mosfet on the high side of the
supply line, I have to drive the gate with 10V **more** than the supply
voltage. This is correct yes?
This is where the question comes in. I am looking at the option of using the
IRS2001 to switch the high side fet. But looking at the datasheet, I am
confused. How can the IRS2001 generate a voltage greater than VCC without
actually being connected to the high side voltage????? There is no talk of a
charge pump in the description and in any case it does not know what
potential the fet is connected to..
Maybe it is not suitable for my application as the IRS2001 seems to be used
for switch mode power supplies? I can't make sense of the first diagram on
the datasheet.
here is a link to the datasheet:
http://www.irf.com/product-info/datasheets/data/irs2001spbf.pdf
OK so if the above IC is not suitable, I have been looking at the MAX621.
http://datasheets.maxim-ic.com/en/ds/MAX620-MAX621.pdf
This one looks to be more straight forward. But I'm not sure how this IC
will go with 20Khz switching. There are many **low side** mosfet drivers
that are in the 2 to 7 amp range to ensure that the mosfets are hard on or
hard off within a few nS. This one doesn't look like it will do anywhere
near that switching current.
Any other ideas for a high side N channel driver IC that packs a punch?
job.
the datasheet.
