high value blue color capacitor
jhunax
what is the main purpose of this capacitor in the tv circuit? usually it is connected at the horizontal output transistor in parallel.
common value 101/2kv or 3kv.
GenusCanisLupus
Hi
It will more than likely be a retrace timing capacitor (safety cap).
If you read through this then you will get a better idea of exactly what it does.
www.repairfaq.org/sam/reppic/horiz-tv.pdf
Hope that helps.
Soldertraining
Apr 11, 2017
18
The colors of capacitors describe the types of capacitors. The color used to identify the components or parts on the circuit board. The round blue colored balls with dots indicate that its a capacitor. Same as other colors are used for other components.
