high voltage amplifier
Alexander
Does anyone know a way to build DC amplifier with +/-10V input and
+/-300V output ?
Thanks in advance.
Alexander.
W
Winfield Hill
Alexander wrote...
input and +/-300V output?
We show a simple technique that uses ordinary parts (see
page 169 of our book, The Art of Electronics). This one
can go from 10 to 1000V, but by a simple extention of the
scheme one can make bipolar amplifiers that can go as high
as +/-600 volts. I can send you a pdf of the schematic of
our AMP-36 dual HV amplifier circuit board if you like.
An alternate (more expensive) approach is to use one of the
commercial high-voltage amplifier modules offered by Apex,
such as their PA95 for $124 each. They also have the PA97
for only $56, but it lacks a protective output current limit
and other basic features. http://www.apexmicrotech.com
- Win
John Popelish
Alexander said:
+/-300V output ?
Such a design would require more specs than that.
What output power do you need?
What minimum and maximum frequency must be amplified?
What kind of load must the amplifier drive?
K
Ken Smith
+/-300V output ?
There are N channel MOS-FETs that work up to these voltages. Two of these
in series would make a good output stage for the amplifier. If you only
need low frequencies, I'd suggest you drive the gates with photo-voltaic
opto isolators.
Opto on pull up
+/-10V signal ---!+\ !-->!--!
! ------/\/\/\--! !--- GND
! ! Opto on pull down
! C1
!---------/\/\/-- Vout
! 9xR
\ R
GND
Alexander
Thanks to all who replied to my problem.
Alexander.
