High voltage High Ron SiC mosfet. Is this simulated Ron realistic?
GLR
Jul 12, 2024
5
Hi guys... is realistic the following simulates Rdson(iD) for a High Voltage SiC mosfet belonging to high-Ron class? Is acceptable for you a similar Rdson(iD) of a commercial SiC mosfet? What is your opinion? :)
[Ohm]vs[A]
14,311
Looks a bit sketchy. Compare to the datasheet of a real SI-C MOSFET (example). This example is for a low resistance SI-C MOSFET, but the general form of the the characteristic is so completely different from your simulation:
Tip: get a spice model from the manufacturer for the specific SI-C MOSFET you want to simulate. Observe any possible limits of the model.
  • Like
Reactions: GLR
GLR
Jul 12, 2024
5
Thank you so much Harald... your reply is very argumentative and enlightening.
I'm trying to design a 2000V 1000mOhm SiC MOSFET for non-linear uses
GLR
Jul 12, 2024
5
Surely the logarithmic horizontal iD axis complicate the graph, perhaps unusefully...
Here is the lin-lin graph
GLR
Jul 12, 2024
5
Is such a set of output characteristics -that has a dynamic range contained in 1V- coherent and useful in non-linear applicative uses for a 2000V - 800mOhm SiC mosfet?
Delta Prime
Jul 29, 2020
2,995
It is neither argumentative or enlightening,
You're dealing with Silicone Carbide,what do you want?
