High Voltage Stun Gun !
Fahad1
Feb 23, 2004
4
Hi
I completed this project
http://www.electronics-lab.com/projects/science/016/index.html
but I feel hard to make high voltage transformer 1000v /6000v
and one could help me and tell how I can construct this transformer with more detail .. ???
Thankx
audioguru2
Apr 6, 2004
12,022
Fahad,
Don't wind the transformer windings with your hand, or the wire will get twisted. Just spin the ferrite like a winch, and let the roll of wire also spin.
hotwaterwizard2
Jan 8, 2004
2,022
Usually a varible speed Drill running real slow works well if you mount it in a vice. Run a screw and nut thru the core and put it in the drill. A Lathe works even better.
attackbat
Jun 24, 2005
Any way to modify this or build one that will only discharge when the prongs touch the target without continuously sparking?
ante1
Jan 24, 2004
4,136
Hi attackbat,
Welcome to our forum.
You have to increase the distance between the electrodes, that’s all!
rfranzk
Jul 11, 2005
28
I have completed this project and found nice output transformers at amazing1.com. I used the secondary of the output transformer for some nice kv voltage. This circuit will also drive an automotive ignition coil for approximately 40kv at this time using 8 AA batteries for power supply.
Serhiy
Jul 31, 2005
HI
Can anybody tell me how to make T1 in this schematic diagram because I can not get it anywhere?
steven2
Jan 19, 2004
1,698
:)dont worry about t1 if you biulfing this stun gun there are alternatives like a flyback driver circuit that not only powers flyback transormers but any transformer in reverse  mode this will give you some good arcs to  look at the topic hand powerd generator  i used 2x 6kv ceramics to make a mini marx generator  and this alone would be an ideal adition  as it put out fat arcs when powerd up from the hand powerd generater
nacromonger
Oct 23, 2005
hi there anychance of some help i have built on bread board the circuit ,have got about 650v across pins but have trouble with pulse transformer.imade one as per instructions but does'nt work .6ohms across primary winding+102ohms acrosssecondary,any ideas give us a bell.
Labtyd2
Feb 2, 2006
I have no idea what any of this is. I don't know much about electronics or anything. Is there any way of findind this in english? As in something I can understand?
MP1
Dec 7, 2003
3,397
Everything here is in plain English. This is a site for electronics enthusiasts. What are you having a problem to understand?
MP
Labtyd2
Feb 2, 2006
Just about everything. I'm not all that into this kind of stuff. I'm trying to learn but I wouldn't know where to go to learn all this. Basically just wanted to try making this.
