Mike
- Jan 1, 1970
- 0
Ok I have a Hitachi Projection TV Mod 43FDX01b. That is pulled down
from the top about a foot, and rolled over, and Pulled up from the
bottom about a foot. and it looks like the convergence amp is turned
off. I checked the Vert circuit, and my 26v line is fine, all the
caps in that circuit are fine too. Diodes look good and so do the
transistors.. I know that if there was a problem in the Vert circuit,
like the amp going bad, the HV protect circuit would shut down the
set. but this is not happening. I've seen a lot of problems with the
Digicon board in the past, but I have never seen it couse the picture
to compress like this.
Has anyone else seen this?
I have pulled the Digicon board out and looked for bad solder
connections, but didn't find any, and no bad solder connections on the
main board. Any help on the would be great..
Thanks Michael
Thanks Michael
