hk lucas 600 poweramp sub
piem
Jun 13, 2024
5
howdy,
i'm trying to fix the amplifier of the subwoofer of an hk lucas 600. i found a related thread here on this forum.
the fuse were blown, and i found that 2 of the output transistors were shorted. so i replaced all four on the board, 2x MJ4032 + 2x MJ4035, with MJ21195G and MJ21196G. now the fuses are not being blown anymore when powering on the device, but the sub produces a hum and 2 of the output transistors are overheating, so i quickly turned off power. the 2 output transistors that are overheating is the pair that i changed even though they were not shorted.
did i pick the wrong replacement parts? any clue how to debug the issue?
thanks, piem
The originals first up are high gain darlington....your replacements are not.
The originals although obsolete, are still availible apparently in the US and the UK on Ebay at least.
piem
Jun 13, 2024
5
thanks for your answer @davenn, and @Bluejets.
i did, but i guess i have done it wrong. here are the links to both datasheets and the specs i looked at:
old darlington pair (MJ4032 / MJ4035)
- Vcbo/Vceo 100V
- Vebo 5V
- Ic 16A
- Ib 0.5A
new transistor pair (MJ21195G / MJ21196G the ones i picked)
- Vcbo/Vceo 400/250V
- Vebo 5V
- Ic 16A
- Ib 5A
@Bluejets, what new parts would you recommend as a replacement?
Delta Prime
Jul 29, 2020
2,995
Do you have a schematic this is all I could find.
Do you know what year your unit is? the number of the PCB itself and what revision it is?
Can you take a photo of your board both sides component side,solder side, please thank you.
Happy belated welcome to Maker Pro!:)
  • hughes-kettner-600-lucas.pdf
  • hughes_kettner_lucas_600_service_manual.pdf
piem
Jun 13, 2024
5
Thanks a lot Delta Prime. I used those schematics https://medias.audiofanzine.com/files/hk-lucas-600-477740.pdf
I believe those are from the late 90's, but i don't have a specific year.
cheers, piem
Similar threads
