[email protected]
- Jan 1, 1970
- 0
Any moidification required for UK phone useage?
Jasen said:BT phone plugs use pin 2 and 5 instead of 3 and 4 on RJ 11
whatever you do it will not ring your phone.
the "USB powered" version will not work.
the bottom version looks to be the best of the three
the circuit looks harmless.
no guarantes on how well the called party will be able to hear you
itsm they'll mostly be hearing their own voice delayed
by the internet lag.
If you call someone else who has the same setup you may end up
listening to a repeating echo.
Bye.
Jasen
Adam said:Most phones , or cordless handets go rj11 with centre 2 pins, thanks
for the lookout though.
Telephone signalling not my strong point , but guessed there must be a
catch , something to do with UK 3 wire and bellringer capacitor as well
guess.
Spotted that one , there isn`t -5V on USB so no way is -5 and +5 going
to give you the +9V need for off hook status.
Well on that advice had to try it
And you spotted that one, test subject binatone cordless, circuit built
used 2.2uF rather than 3.3uF , because was all had to hand.
Didn`t manage to try out chat cord software because needs XP , test PC
running ME, using
https://www.voiptalk.org/products/really_useful_signup.php,not an
affiliate link just a free UK geo number, running on Xlite, works very
well with a headest, works, kind of, with the adapted binatone.
As you anticipated , tests to mobile phone from binatone>adpapter>PC
resulted in a loud delayed echo being delivered back to the mobile,
call clarity on the binatone was fine.
Some twiddlling with mic gain did appear to make some differnce, but
also wondering on other factors, wonder if chat cord software has any
form of echo cancellation built in, main feature appears to be to
recognise DTMF tones from keypad.Will try adapter on XP installed
machine.
Is the substitution of capacitor value critical?
Would a transformer balanced solution be any better?
