Homebrew HV hiZ scope probe
Robert Baer
Fred said:
Takes forever to converge.
I softened the analysis a bit by making the pulse risetime 20ns, similar
to your HP3312A, but it's still excruciatingly slow.
How sure are you of the resistor model? Have you considered making it a
uniform RC line (U) model? I'll try that in a while, it might converge
faster.
There's a pole at around 67 Hz that needs addressing.
I added 3 feet of RG179, which i have a model for, which is similar to
RG175, for which I don't. The inevitable quarter-wave spikes appear at
around 46MHz, et seq. 60 ohms in series with each end of the coax tames
this, and we now have a 3dB rolloff around 70MHz, making risetime about
5ns. That's why resistive cable is used in commercial probes.
I'd do what Tektronix do, and do all compensation at the 'scope end.
Bear in mind that Tek's 40kV probes used to run their HV resistor in an
atmosphere of Fluorcarbon 114 vapor, which needed topping up from time to
time. I don't know what they use these days in HV probes, but I doubt it's
FC.
Try this, it's your circuit with 3 feet of coax. Do an .ac analysis, with
and without the 60 ohm resistors.
I see you made Cs, capacitance from floating shields, a lot larger =
8pf instead of my wild guesstimate of 0.1pf.
Those floating shields allow defined and predictable capacitive
coupling across the resistors; the capacitance from them to "outer
space" ground seems to be undefinable: coax capacitance runs
(log(D/d))^-1 and with a theoretically infinite D (or very large D in
reality),the capacitance is rather close to zero.
I picked 0.1pf as an estimate to that "zero"; seems you picked a huge
8pf.
I did not know of that uniform RC line (U) model; it would be an
excellent choice; better than the pi-pad scheme.
Values can easily be calculated on basis of resistor diameter,
dielectric material and floating shield diameter.
Seems that an eXplicit shield around the floating shield makes for
more trouble.
F
Fred Abse
No, I refer you to your previous post,<[email protected]>:
"TEXT 168 160 Left 2 !.PARAM Cr=10p, Cs=7.9p, Rp=200Meg"
Cs=7.9pF
Exact copy of your published schematic, with the addition of 3 feet of
cable, and two resistors.
I wondered about that.
The same value occurs in the listing on your website.
I didn't pick it, you did ;-(
F
Fred Abse
** This is what i have, before i saw your response; not too bad
considering simple compensation and implicit coax of indeterminate (but
limited) length to scope end.
You can't ignore the effect of what is, in effect, an open-circuit quarter
wave line, at a frequency within the intended bandwidth of the probe.
3 feet of 0,66 velocity coax, terminated in a large resistance will
resonate at about 54MHz, and ring like a bell. That's why resistive cables
are used.
Jeroen Belleman
are used.
Do you have any idea where one can buy resistive cable?
Jeroen Belleman
TheGlimmerMan
Jeroen Belleman
Modern automotive "spark plug wire". Has a "graphite core". Specific
R per foot value. Meant to be an emission suppressive passage for HV
pulses being fed to the plugs, something which generally causes a pretty
big magnetic spike to emanate.
There were folks in the '50s and '60s (hams) who even went so far as to
fully ground shield each of their spark plug wires to reduce the problem.
Then they (those 'they' people) came out with the better, resistive wire
and the problem sufficiently subsided..
May not be exactly what you seek, but that is the only version I am
aware of.
Spehro Pefhany
Jeroen Belleman
Probably easiest to buy a scope probe and cut the ends off!
See: Patent number: 2883619
Issue date: Apr 21, 1959
Jamie
aware of.
We had an old car here once that I decided to tackle a blower problem
in the heating and ventilation system. THe problem, no blower operation.
After tearing out the blower box under the glove compartment, which
was a big job getting to, I found there was nothing wrong with the
blower motor. The plug was too hard to get to so it wasn't an easy
option to simply test it before hand. So I went to the control switch,
that worked ok. So I then started ripping apart the harness, they had
put a resistor wire in the harness for the blower to reduce the brush
noise in the electrical system.
At that point, I really didn't care much for the car, it was getting
old, so I just hung a copper wire outside of the harness.. I can say
this, not only was that wire there to reduce noise, it also served as a
voltage drop to the blower, that thing was like a wind tunnel afterwards :)
Jamie
F
Fred Abse
I suspect that probe manufacturers get their resistive cables made to
order. That implies a few thousand feet to get a cable manufacturer
interested.
*Almost* the same effect can be got by putting a small (tens to hundreds
of ohms) in series with each end, if all you want is to damp resonances in
a probe.
You might try a few of the "usual suspect" cable manufacturers. There are
a few specialist cable companies in Germany who claim to make small
quantities of specials to order.
Jeroen
interested.
It's the scope probe type cable I'm after indeed. I contacted Draka
to see if they could deliver any. They said they were willing to make
it to my specs, provided I'd buy at least 1km. I'd need a dozen or so
five-meter pieces. Oh well. Maybe Spehro was right: Just chop of the
unwanted ends off a scope probe.
a probe.
I tried that. Not good enough.
Thanks, I'll shop around.
Jeroen Belleman
Robert Baer
Robert said:
I see you made Cs, capacitance from floating shields, a lot larger = 8pf
Those floating shields allow defined and predictable capacitive coupling
across the resistors; the capacitance from them to "outer space" ground
seems to be undefinable: coax capacitance runs (log(D/d))^-1 and with a
theoretically infinite D (or very large D in reality),the capacitance is
I picked 0.1pf as an estimate to that "zero"; seems you picked a huge 8pf.
Seems that an eXplicit shield around the floating shield makes for more
trouble.
Oops..now i see an unreasonable Cr of 10pf; that would total to 50pf
on a resistor; VERY hard to implement.
Dimensions:
^-------metal end caps-------^
Metal end caps 0.285 dia, body 0.265 dia, end cap width 0.180, and
end-to-end width 2.085 inches
Most plastics (for insulation and support of the floating shield)
have roughly 3 for dielectric constant, and a tube minimum diameter
would contact only the end caps at best; 1/16 wall thickness at smallest.
Robert Baer
faster.
FC.
Version 4
SHEET 1 2064 680
WIRE -352 -16 -448 -16
WIRE -208 -16 -272 -16
WIRE -64 -16 -128 -16
WIRE 80 -16 16 -16
WIRE 224 -16 160 -16
WIRE 448 -16 304 -16
WIRE 592 -16 528 -16
WIRE 736 -16 672 -16
WIRE 880 -16 816 -16
WIRE 1024 -16 960 -16
WIRE 1280 -16 1104 -16
WIRE 1328 -16 1280 -16
WIRE 1408 -16 1328 -16
WIRE 1568 -16 1488 -16
WIRE 1760 -16 1664 -16
WIRE 1952 -16 1840 -16
WIRE 1984 -16 1952 -16
WIRE -352 16 -352 -16
WIRE -272 16 -272 -16
WIRE -208 16 -208 -16
WIRE -128 16 -128 -16
WIRE -64 16 -64 -16
WIRE 16 16 16 -16
WIRE 80 16 80 -16
WIRE 160 16 160 -16
WIRE 224 16 224 -16
WIRE 304 16 304 -16
WIRE 448 16 448 -16
WIRE 528 16 528 -16
WIRE 592 16 592 -16
WIRE 672 16 672 -16
WIRE 736 16 736 -16
WIRE 816 16 816 -16
WIRE 880 16 880 -16
WIRE 960 16 960 -16
WIRE 1024 16 1024 -16
WIRE 1104 16 1104 -16
WIRE 1568 16 1552 16
WIRE 1680 16 1664 16
WIRE 1280 32 1280 -16
WIRE 1328 64 1328 -16
WIRE 1952 64 1952 -16
WIRE 2000 64 1952 64
WIRE 2000 80 2000 64
WIRE -352 112 -352 80
WIRE -272 112 -272 80
WIRE -272 112 -352 112
WIRE -208 112 -208 80
WIRE -208 112 -272 112
WIRE -128 112 -128 80
WIRE -128 112 -208 112
WIRE -64 112 -64 80
WIRE -64 112 -128 112
WIRE -32 112 -64 112
WIRE 16 112 16 80
WIRE 16 112 -32 112
WIRE 80 112 80 80
WIRE 80 112 16 112
WIRE 160 112 160 80
WIRE 160 112 80 112
WIRE 224 112 224 80
WIRE 224 112 160 112
WIRE 304 112 304 80
WIRE 304 112 224 112
WIRE 448 112 448 80
WIRE 528 112 528 80
WIRE 528 112 448 112
WIRE 592 112 592 80
WIRE 592 112 528 112
WIRE 672 112 672 80
WIRE 672 112 592 112
WIRE 736 112 736 80
WIRE 736 112 672 112
WIRE 784 112 736 112
WIRE 816 112 816 80
WIRE 816 112 784 112
WIRE 880 112 880 80
WIRE 880 112 816 112
WIRE 960 112 960 80
WIRE 960 112 880 112
WIRE 1024 112 1024 80
WIRE 1024 112 960 112
WIRE 1104 112 1104 80
WIRE 1104 112 1024 112
WIRE 1280 144 1280 96
WIRE 2000 144 1952 144
WIRE -448 160 -448 -16
WIRE -32 160 -32 112
WIRE 784 160 784 112
WIRE 2000 192 2000 144
WIRE 1328 224 1328 144
WIRE 1552 224 1552 16
WIRE 1680 224 1680 16
WIRE -448 272 -448 240
WIRE -32 272 -32 224
WIRE 784 272 784 224
FLAG 1328 224 0
FLAG 2000 192 0
FLAG 1984 -16 scope
FLAG 1280 144 0
FLAG -448 272 0
FLAG 784 272 0
FLAG -32 272 0
FLAG 1680 224 0
FLAG 1552 224 0
SYMBOL voltage -448 144 R0
WINDOW 0 8 7 Left 2
WINDOW 3 11 105 Left 2
WINDOW 123 11 123 Left 2
WINDOW 39 11 141 Left 2
SYMATTR InstName V2
SYMATTR Value PULSE(0 250 0 20n 20n 1m 2m 10)
SYMATTR Value2 AC 1
SYMATTR SpiceLine Rser=50
SYMBOL cap 1296 96 R180
WINDOW 0 24 56 Left 2
WINDOW 3 24 8 Left 2
SYMATTR InstName C31
SYMATTR Value 2478p
SYMBOL res 1312 48 R0
WINDOW 3 30 126 Left 2
SYMATTR Value 4.008Meg
SYMATTR InstName R31
SYMATTR SpiceLine tol=0.1 pwr=1
SYMBOL cap 1984 80 R0
SYMATTR InstName C32
SYMATTR Value 22p
SYMBOL res 1968 160 R180
WINDOW 0 36 76 Left 2
WINDOW 3 36 40 Left 2
SYMATTR InstName R32
SYMATTR Value 1Meg
SYMBOL cap -368 16 R0
WINDOW 0 20 11 Left 2
SYMATTR InstName C1
SYMATTR Value {Cr}
SYMBOL cap -288 16 R0
SYMATTR InstName C2
SYMATTR Value {Cr}
SYMBOL res -368 0 R270
WINDOW 0 -24 71 VTop 2
WINDOW 3 68 60 VBottom 2
SYMATTR InstName R1
SYMATTR Value {Rp}
SYMBOL cap -224 16 R0
SYMATTR InstName C3
SYMATTR Value {Cr}
SYMBOL cap -144 16 R0
SYMATTR InstName C4
SYMATTR Value {Cr}
SYMBOL res -224 0 R270
SYMATTR InstName R2
SYMATTR Value {Rp}
SYMBOL cap -80 16 R0
SYMATTR InstName C5
SYMATTR Value {Cr}
SYMBOL cap 0 16 R0
SYMATTR InstName C6
SYMATTR Value {Cr}
SYMBOL res -80 0 R270
SYMATTR InstName R3
SYMATTR Value {Rp}
SYMBOL cap 64 16 R0
SYMATTR InstName C7
SYMATTR Value {Cr}
SYMBOL cap 144 16 R0
SYMATTR InstName C8
SYMATTR Value {Cr}
SYMBOL res 64 0 R270
SYMATTR InstName R4
SYMATTR Value {Rp}
SYMBOL cap 208 16 R0
SYMATTR InstName C9
SYMATTR Value {Cr}
SYMBOL cap 288 16 R0
SYMATTR InstName C10
SYMATTR Value {Cr}
SYMBOL res 208 0 R270
SYMATTR InstName R5
SYMATTR Value {Rp}
SYMBOL cap 432 16 R0
SYMATTR InstName C11
SYMATTR Value {Cr}
SYMBOL cap 512 16 R0
SYMATTR InstName C12
SYMATTR Value {Cr}
SYMBOL res 432 0 R270
SYMATTR InstName R6
SYMATTR Value {Rp}
SYMBOL cap 576 16 R0
SYMATTR InstName C13
SYMATTR Value {Cr}
SYMBOL cap 656 16 R0
SYMATTR InstName C14
SYMATTR Value {Cr}
SYMBOL res 576 0 R270
SYMATTR InstName R7
SYMATTR Value {Rp}
SYMBOL cap 720 16 R0
SYMATTR InstName C15
SYMATTR Value {Cr}
SYMBOL cap 800 16 R0
SYMATTR InstName C16
SYMATTR Value {Cr}
SYMBOL res 720 0 R270
SYMATTR InstName R8
SYMATTR Value {Rp}
SYMBOL cap 864 16 R0
SYMATTR InstName C17
SYMATTR Value {Cr}
SYMBOL cap 944 16 R0
SYMATTR InstName C18
SYMATTR Value {Cr}
SYMBOL res 864 0 R270
SYMATTR InstName R9
SYMATTR Value {Rp}
SYMBOL cap 1008 16 R0
SYMATTR InstName C19
SYMATTR Value {Cr}
SYMBOL cap 1088 16 R0
SYMATTR InstName C20
SYMATTR Value {Cr}
SYMBOL res 1008 0 R270
SYMATTR InstName R10
SYMATTR Value {Rp}
SYMBOL cap -48 160 R0
SYMATTR InstName C21
SYMATTR Value {Cs}
SYMBOL cap 768 160 R0
SYMATTR InstName C22
SYMATTR Value {Cs}
SYMBOL ltline 1616 0 R0
SYMATTR InstName O1
SYMATTR Value RG179
SYMBOL res 1504 0 M270
WINDOW 0 32 56 VTop 2
WINDOW 3 0 56 VBottom 2
SYMATTR InstName R11
SYMATTR Value {R}
SYMBOL res 1856 0 M270
SYMATTR InstName R12
SYMATTR Value {R}
TEXT 264 256 Left 2 !.ac dec 1000 1 200meg
TEXT 264 -208 Left 4 ;40KV 2E9 ohms HV scope probe
TEXT -144 -120 Left 2 ;Ohmite MOX2-131007FE\nin pi net distributed form
TEXT 672 -120 Left 2 ;Ohmite MOX2-131007FE\nin pi net distributed form
TEXT 272 384 Left 2 !.model RG179 LTRA (\n+ len=3\n+ L=.1u\n+ C=19.5p\n+ R=252.5e-3\n+)
TEXT 272 328 Left 2 !;.step param R 10 100 10m \n.param R = 60
TEXT 272 -176 Left 2 ;3 feet RG179 (similar to RG175) added to model\nBelden 83265 data used.
It has been a loooong time; Tektronix made two high voltage probes -
one with a significantly higher voltage rating.
The one i have _did_ have the liquid inside but that has slowly
leaked out over the ages; it is the P6015 rated at 20KV, 40KV peak.
I think that is the top end in voltage.
Robert Baer
are used.
Perhaps, but us mortals with a limited budget cannot order umpteen
thousand feet of coax with a resistive center.
The P6015 used ten feet of coax with resistive center (direct quote
from manual).
Cannot say what its resistance is..i read 657 ohms end-to-end on the
cable, and the schematic states 150 ohms 10% at probe end, implying the
coax center is about 500 ohms (~5 ohms per foot).
Since you specified 75 ohm cable, the R should then be 75 ohms
instead of 60 ohms (pickie).
Robert Baer
Jeroen Belleman
Yes...all it takes is a lot of $$ for the special order.
Unless one is VERY fortunate to find it in a surplus house or willing
to rat out the cable from a P6015..
Robert Baer
aware of.
Did a Baby Bird (GooGull) snoop..NGK resistive wires "utilize a
construction method known as "variable pitch" wire winding to create
resistance to radio frequency interference. NGK wires have a lower
resistance than conventional carbon core wires (8k ohm/meter vs. 16k
ohm/meter)."
So these "better" spark plug wires have a "mere" 2.4K/foot
resistance, which exceeds a desirable amount by about an order of magnitude.
Excellent suggestion, however..
Robert Baer
SACRILEGE!!!
Robert Baer
Jamie said:
how many pine trees had to be cut down to build that wall for you?
Jamie
If you were a true tree huger, you _would_ "pine" for them..
Robert Baer
interested.
a probe.
* Check.
