Miguel Lopez
- Jan 25, 2012
- 255
- Joined
- Jan 25, 2012
- Messages
- 255
Hello everyone
The need for a signal generator in an electronics workbench is out of discussion. I built a tiny signal generator in the past, that I've been using till now. It is very limited as it gives up to 50 kHz of sinewave. It has been very useful but now I need something else.
My intention is to built another sinewave signal generator with to independent outputs. One for low frequency (up to about 300kHz) and another output from 500kHz to about 5MHz, keeping distortion in low levels. The purpose of this device is to experiment with modulation and demodulation
I will also include two other outputs with 1kHz and 465kHz fixed frquencies in order to test radio and audio circuits, and use them as standards.
For the low frequency section and the 1kHz fixed frecuency, I used the attached circuit (R=1k).
I used an LM324 for the 1kHz output and LF353 for the variable frequency output. This variable output will have ranges (switching capacitors) and fine adjustment (single potentiometer)
On further posts I will show how I got throught this project.
