[email protected]
- Jan 1, 1970
- 0
Greetings,
Need a little help here. I am building the crystal radio plans here:
http://hibp.ecse.rpi.edu/~john/xtal.html
It calls for an Output Transformer. I 'Think' I have one (Caltronics
2510). The problem is that I don't have the docs for it. The
secondary terminals are labeled in Ohms and it has a 4 Ohm terminal
with Common just like the plans call for which is fine but the
Primary Terminals are labeled like this
10W, 5W, 2.5W, 1.25W, 0.62W and Common
First question: Is this the type of Transformer the plans are calling
for?
Second question: Which of the terminals would be the 10,000 ohm input?
(or is there one??)
Third question: How would a person measure the impedance of a
Transformer like this?
Fourth question: Would it be possible to wind your own and how would
you figure the turns ratio for a transformer of this type?
Fifth question: how is this different from a ordinary power
transformer in design?
Sixth Question: Why is mine labeled in Watts? if the W is for Watts?
Thanks in advance for your help!
for?
(or is there one??)
