Capoot
- Jan 1, 1970
- 0
You will probably be disappointed in your crystal radio's ability to drive a
speaker even with an optimal transformer. The transformer will allow you to
use commonly available 32 ohm stereo phones. Hook up the phone jack so that
the phones are in series. While your ohmmeter will not measure impedance,
it will give you an indication of which windings are high and low. Use the
highest resistance pair for the input and the lowest for the speaker or
phone. Power transformers are optimized for 60 cycles but will operate at
audio frequencies. Use the lower resistance filament winding for the phone.
Crystal earbuds were by far the best transducers that I ever used on my
sets. No transformer needed and plenty of volume even with minimal or no
antenna. Hook up two in parallel. Mouser has them (25CR025, 25CR035,
25CR060) for $2.03 each.
http://www.mouser.com/catalog/616/948.pdf
I had a lot of fun playing with crystal set circuits in my youth. A great
introduction to radio/electronics.
Ray
Ray
