Hot knife
D Yuniskis
[Obviously, the weekend has been spent disassembling
and repairing/replacing a variety of "toys" :-/ ]
What tricks can be brought to bear disassembling
plastic items that have been solvent welded (or glued)
together IN A COSMETICALLY ACCEPTABLE MANNER?
I typically use a heated exacto knife to slice the
item on the apparent "seem/weld". But, this is
time consuming, wasteful of energy and still doesn't
leave very "clean" results.
I've looked into purchasing a *real* "hot knife" but
I suspect they don't have the thermal mass to deal
with items as massive as most plastic enclosures (?)
Geoffrey S. Mendelson
I've had good luck with ham radio battery packs for handhelds by freezing them
and then hitting them on a stone step. The welds crack open.
Geoff.
Geoffrey S. Mendelson, Jerusalem, Israel [email protected] N3OWJ/4X1GM
New word I coined 12/13/09, "Sub-Wikipedia" adj, describing knowledge or
understanding, as in he has a sub-wikipedia understanding of the
situation. i.e possessing less facts or information than can be found in
the Wikipedia
N
N_Cook
D Yuniskis said:
Squash, long ways first, in a carpenters vice usually splits enough in the
middle of the run, to make a start, and then blades. If nothing seems to be
happening , before you chicken out, try diagonally or short ways. Sometimes
will make a small tear into the cosmetic area but I've never had a full tear
into the fare surfaces. Somtimes distorts internal heatsink if up against
the case
Allodoxaphobia
In the same vein, I try the freezing and then use an old wood chisel and
a light mallet along the seam. Sometimes it takes several passes around
the weld. The last bit is usually done with a thin, wide knife blade.
The corners -- if any -- can be the toughest...
GL
Jonesy
D Yuniskis
Hmmm.... I was just about to tackle a small UHF transceiver.
I'll try that (if it doesn't work, I can always trash the
thing :< )
D Yuniskis
N_Cook said:
D Yuniskis said:
the case
Ouch! This seems more likely to yield a *mess*...
D Yuniskis
thing :< )
I tried freezing and then wacking with a hammer (i.e., as
if trying to dislocate one side of the weld from the other).
No good.
I'll try a sharp wood chisel on the seam next.
Then, resort to the heated knife. :<
