MidAtlantian
- May 12, 2015
- 36
- Joined
- May 12, 2015
- Messages
- 36
I'm sure that "how components fail" is a huge topic, but right now I am focused on how a 555 chip, especially the cmos version, is likely to fail.
There are two main conditions for failure: when it "shouldn't have failed", and when it is in some way overloaded: either with voltage or current. What are the chances that the output (pin 3) of the dead chip would end up being high in either of these failures? And perhaps most importantly: how, apart from experience, would one find out this sort of information?
Also, do transistors ever fail in a way that they continue to conduct across the emitter-collector; that is, a short across the base region?
Thank you.
Thank you.
