How ac work in single phase
linux
Jun 27, 2017
17
how ac waveform work in single phase from dam/power house
there is neutral and live how does it work in real does one line goes up and secound goes down??
14,271
There is no up and down.
A voltage is the difference in electric potential between two points (or wires in this case). There is no absolute 0V potential. Which one is neutral and which one is live is a matter of definition.
By convention "neutral" has the same potential as earth, the ground you stand on. These two are often connected.
The potential on the "live" wire changes with time from negative to positive and back with a sinusoidal waveform at mains frequency (typically 50 Hz or 60 Hz).
linux
Jun 27, 2017
17
hi
then neutral remain zero??
14,271
zero with respect to what?
Remember: There is no absolute voltage. No point in the universe has a voltae of 0 V. Voltage is always the difference in potential between two points. So if neutral is connected to earth, then the voltage (potential difference) between neutral and earth is 0V.
linux
Jun 27, 2017
17
but i dont understand how sin wave work 120/230v ?
does it go above neutral 120/2, 230/2V
and next cycle down?
linux
Jun 27, 2017
17
when we place tester it work only with live not neutral?
14,271
120 V or 230 V is the RMS voltage. Read this article for detailed information.
No, no, no. You always measure between two points/wires. You cannot measure a voltage on a singlepoint/wire.
linux
Jun 27, 2017
17
yes live and earth from body itself can you sketch how sin wave work in single phase
14,271
Please read the article I linked in post #7.
Do you know how DC works?
linux
Jun 27, 2017
17
yes i know there is 5v mean gnd and 5v
10v mean 0v gnd and 10v
linux
Jun 27, 2017
17
it's just the reference about which the signal oscillates
this state all info...i get it
Minder
Apr 24, 2015
3,561
As has already been stated, with 1phase, selecting one conductor for neutral is purely arbitrary.
The one place where it is more clearly defined but not necessarily connected to earth, is the Star point of a 3 phase transformer where one phase and the star point (neutral) is used for 1ph.
M.
