How can I use PWM to control a Solenoid Valve through a PLC?
kunalv
May 23, 2020
I am looking at controlling the flow-rate of one liquid through a Solenoid Valve in a closed loop system, which takes input from another stream of liquid.
Objective is to mix the two liquids at the right concentration downstream.
I was able to source a PWM enabled valve, but how do I send the PWM signals to the valve? I have read about Controllers and Drivers, but don't understand too much as I am not from an Electronics background.
Any guidance would be appreciated. Thanks :)
dave9
Mar 5, 2017
1,191
You might want to mention and link to the specific parts. Odds are that the valve has a suggested PWM driver for it and a datasheet for that with instructions to aid in implementation.
