Mylinux
- Jan 1, 1970
- 0
how can we change a motor from 220V to 12 V ?
Bryan Hackney said:Call up your motor distributor, and ask for a 12V
motor in the same size and power as the existing motor.
You might want to specify AC or DC. Current will go up
by about 10x. Please ask a real engineer for help before
placing the order.
Next question?
sorry , poor written computer english; it should be read as:
You want to rewind a 220vac motor to run on 12vdc?Mylinux said:sorry , poor written computer english; it should be read as:
how can we change a motor from 220V AC to 12 V DC?
Basically I would follow Bryan's recommendation. Take the specs of the
220V AC motor to your motor distributor. However if you are asking how
to run a 220V AC motor (system) off a 12V DC supply then I would be
looking at 12 volt to 220V AC inverters.
Ken.
René said:Basically a shunt commutating motor runs off AC as good as DC. If you
connect your vacuum cleaner to e.g. a 24V DC source it might just
turn. (not very hard though)
Mylinux said:How can I run a 12V DC motor from mains power?
no
my original question
how can we change a motor from 220 v to 12 V?
Mylinux said:how can we change a motor from 220V to 12 V ?
