How can we replace the relay in a battery charger by one or two MOSFETs?
Holy Hathaway1
Nov 9, 2018
15
My question : how can we replace the relay in a battery charger by one or two MOSFETs? I imagine a P MOSFET mounted as a polarity protection and directly charging the battery through a schottky, and the voltage of the battery sensed by a BJT thru a voltage divider that will block the MOSFET as the battery reaches 14 volts or so. What would be the values of the components : transistor (N? P?), voltage divider... Can you explain on that?
