How come these alligator clips only transfer electricity when swapped at the battery terminals?
juntjoo
Jun 8, 2015
142
If input the clips on their respective terminals it won't work. And the positive part of this configuration on the barrel connector is on the outside. Not sure what they usually are. I don't recall doing anything with these clips. I can tell you they came with a solar trickle charger product and connects to the solar charger to charge a battery. So I'm guessing they are designed to go the opposite direction maybe? Does that mean there's a "diode" in there restricting electricity flow to one direction? This stuff is still new to me.
Either way, I won't be able to use these to charge to the barrel connector as I'm intending to do will I? If I swap them to get current flow I'll have to rig something up with female barrel connector and an sae one to connect to my motorcycle to charge the battery
[Mod Note: resized image and put inline].
Given it is solar related, guessing there will be a diode in there somewhere.
All I can see is a barrel plug and jumper clips, no idea what goes where from your photo.
Normally would expect negative on the outer sleeve of the barrel plug.
Martaine2005
May 12, 2015
5,318
Again, your explanation and photo doesn’t tell us much.
Is this cable terminated with a DC barrel jack and crocodile clips only?.
No other ‘box’ in between?.
Use your multimeter to check each wire for continuity then swap the probes and check again.
Martin
juntjoo
Jun 8, 2015
142
There's nothing else to see. And I guess the plug polarity is switched because I have the alligator clips switched. I think I'll just splice together a polarity switch/adapter
Audioguru
Sep 24, 2016
3,656
Barrel connectors like you showed are connected with both polarities but usually show a sketch of the polarity used.
The protection diode is called an "idiot diode" because only an idiot will connect the polarity backwards.
juntjoo
Jun 8, 2015
142
I see what you did there.
It's a pair of wires with alligator clips on one end and a barrel connector on the other. Why can't I repurpose this thing for my specific needs? That little solar charger pad that it came with proved to be useless and I want to connect my regular battery charger (with alligator clips) to my SAE pigtail on my motorcycle
Is there really a diode in there somewhere? In the barrel connector itself? There's nothing else to it other than what is in the pic. Just more wire. Nothing along the wires.
bertus
3,877
To check if there is a diode in the plug, you could measure from the plug to the connector both ways on the inner contect and the outer contact using the diode check of the DMM.\
Perhaps the diode is in there to make the circuit "fool" prove.
Bertus
juntjoo
Jun 8, 2015
142
Martin
I think I did that. I'll do it again later then edit this.
Bertus
Yes, I think that is what Martin was getting at. I'll try that and report back later. Thanks...
Haha you guys are funny. Maybe the diode is in there to make the circuit "the biggest moron in the world" proof
Audioguru
Sep 24, 2016
3,656
Years ago I was a technician on the car radio production line. The radios had a huge reversed diode directly across the supply to blow the car's fuse if the radio power polarity was connected backwards by an idiot. A series diode was not used because it would reduce the radio's maximum output power.
Martaine2005
May 12, 2015
5,318
The idiot diode/fool proof thing is very real.
If your cable has a diode, it will probably be in series with one of the wires. Probing the wires both ways will find it.
Edit: you say reversing the leads polarity gets voltage to the jack. This suggests a reverse biased diode in the positive feed (conventional current). It is there so the solar panel charges the battery but the battery can’t feed back to the panel. IMO.
Martin
