How do I implement firing of triac using microcontroller?
arisu1love
Oct 26, 2010
10
I am doing a project where I am using a microcontroller in order to send a pulse to fire a triac. The MCU I am using is from the freescale HCS12 microcontroller family. I would like to know, what software method can I use to send a gate current pulse signal from the microcontroller to the triac?
Software? To create a pulse you turn on an output and then turn it off again.
Hardware is more difficult. Google MOC3021
arisu1love
Oct 26, 2010
10
actually I plan to use the HCS12 microcontroller to fire the triac. however i am stuck in terms of how to program the microcontroller to output a gate pulse during each ac half cycle. Do I use pulse-width-modulation to obtain the gate pulses?
The easiest way is to detect zero crossings and then use a timer to determine when you want the pulse to start.
It may be useful to look at the timing between subsequent zero crossings so that you can determine if you're operating with 50 or 60Hz mains (if that is an issue).
I still think you should look at the MOC3021 or similar. Or is your entire circuit going to be at mains potential?
arisu1love
Oct 26, 2010
10
yes....the entire circuit is going to be at mains potential...I am still worried about connecting the input to detect zero crossing to the microcontroller though...The power supply to the microcontroller can be via an external DC source although I would prefer for it to be tapped from the mains
Not sure if it is safe for the microcontroller pin to be connected to the mains line...although via resistors.
Minder
Apr 24, 2015
3,560
There is also Fairchild AN3006 for a 555 circuit,
You can also use the same principle for a micro, see Triac app notes on Microchip site..
And Fairchild AN3003.
M.
