How do I run a 24VAC solenoid off of a couple of 9V's?
Status
Not open for further replies.
CDRIVE
May 8, 2012
4,960
The solenoid valve used in that video must draw much less current than yours. That said he will be going through 9V batteries faster than sh!t through a Goose!
Thanks for posting the video because we have a much better picture of what's being designed here. I don't see how it can be classified as a rocket though. It does not employ it's own source of thrust. So it's a projectile with fins. :D
Chris
cherrington
Feb 11, 2013
11
Yeah, I think I am just going to order the same valve that he was using because I can't do anything with the one I have now.
I would recommend you get the largest 25V capacitor you can find (say 10,000uF or more) and place it across the 18V output.
That should provide enough current to operate the valve. You don't need it open for long.
CDRIVE
May 8, 2012
4,960
Actually, I find it surprising that your solenoid resistance would be so much lower than the one used in the video. On the other hand I'm surprised that two series 9V batteries would drive the large solenoid valve in that video anyway.
Chris
CDRIVE
May 8, 2012
4,960
I just had a thought because it would be a shame to have to eat the cost of that valve you have. Why not use a power tool battery? Anything from 12V to 18V will certainly power your solenoid.
Chris
CDRIVE
May 8, 2012
4,960
cherrington
Feb 11, 2013
11
Do you think that if I skipped the sprinkler valve and just attached a ball valve to my chamber, and then the barrel to the other end of it, would it release the air fast enough?
CocaCola
Apr 7, 2012
3,635
Yep, that is how most spud guns and and pumpkin cannons do it...
Make sure to get a 'full bore' ball valve, many of the ball valves have much smaller valve holes compared to to the pipe size, example when you use a 1" pipe the valve reduces to 1/2"... Full bore will be a 1" pass through on a 1" valve...
CDRIVE
May 8, 2012
4,960
***** Electronics Point *****
The one stop tech forum where you can get all your electronics questions answered and plumbing too! :D ;)
Chris
CocaCola
Apr 7, 2012
3,635
Several years as a professional home remodeler and builder, I have done my far share of all the building trades ;)...
I also build a PVC, CO2 driven T-shirt shooting rifle for a friend many years ago...
One of the first threads I was involved in here was all about plumbing.
rgfoose
Jul 16, 2025
Get a 9 VDC solenoid for it. About $15. They are latching, so only need power for a couple of seconds. To release the solenoid, reverse polarity for a couple of seconds.
crutschow
May 7, 2021
950
Another newbie necro post.
This thread is over 10 years old, so I doubt the TS is interested in another solution. :rolleyes:
Status
