How do you wire a window to be partially open?
Gus
hardwired sytem
It would be nice to have the system armed and also have a window
partially opened..
Thanks for suggestions on how to accomplish this....
Gus
Allan Waghalter
Mount your switch on the side of the window casing. Then use two different
magnets on the window itself. One positioned to oppose the switch when the
window is down and the second to oppose the switch in the partially open
position. Be sure and have the partially open position small enough that
someone can't come through without moving the window. Also, mount the
switch assembly high enough that someone can't reach through the window to
tamper with it.
Allan
Jim Rojas
I had a few customers in which I install a row of magnets along side the
switch so he can open his window without disarming the system. This was
before vent switches came out.
Jim Rojas
Bob La Londe
Install to NC contacts in parallel or two NO contacts in series.
The Security Consultant
Bob La Londe - Owner
849 S Ave C
Yuma, Az 85364
(928)782-9765 ofc
(928)782-7873 fax
