How does a switch mode amplifier... amplify?
michan
Feb 21, 2015
22
I have had experience with continuous amplifiers that make use of a transistors transconductance to achieve some level of gain, but I am unsure how switch mode amplifiers such as class D or E amplifiers would amplify (voltage, current, or power)? I have tried looking into this online but I have only sources describe how the circuits operate rather than the actual mechanism that creates the gain and creates the amplified signal. I know PWM can be used in these switching amlifiers but that wouldn't produce amplification, just modulation as the name implies. Any help is appreciated, thanks!
14,487
the net has lots of useful answers, no point me repeating all the text
Class D amps ....
https://www.bing.com/search?q=how+does+a+class+D+amplifier+work?&src=IE-SearchBox&FORM=IENTTR&conversationid=
go do some reading :)
Class E amps ....
dont appear to be overly common, and little info online
here's one of the few links I cold find
http://people.physics.anu.edu.au/~dxt103/class-e/
michan
Feb 21, 2015
22
the net has lots ofg useful answers, no point me repeating all the text
Class D amps ....
Class E amps ....
They seem to be really useful for how the circuit operates and the waveform and things but I haven't seen any of the links give a straight answer as to how the signal is amplified. One link mentioned pwm but I don't understand how pwm creates any kind of gain, I would have thought the maximum voltage or current would just be the same value as the peaks of the pulses (voltage or current).
dave9
Mar 5, 2017
1,191
It doesn't directly PWM the input signal. It is like an opamp in that it uses a feedback loop with (either a fixed or adjustable depending on the amp IC) a voltage divider to create a lower apparent output signal (at that point in the circuit), which the PWM regulator uses to modulate the power rails to produce the desired real output signal level which matches the input level after the resistive divider drops the signal by a multiple equal to the target gain # - only going back as feedback to the opamp-like portion of the circuit, while the gain result goes to the load.
Thus the maximum output voltage is the power supply voltage minus the drop across the switching transistor, and maybe a little more if there's an inductor or other resistance on the outputs, or less if the gain isn't set high enough to need that much voltage.
Do you know how a switch mode power supply works? If so, a class D amplifier is nothing more than a switch mode power supply whose output voltage follows an audio signal.
The key is switch mode.
A transistor used as a switch amplifies a digital (on or off) signal. Using a MOSFET (which any current class D amplifier does,) you can get a super high power gain in a digital amplifier with a single stage. For example, say I have a 5V signal that can supply only 1mA of current . That is 5 mW. If I apply that signal to a logic level MOSFET which switches 50V to a 10A load, that is 500W for a power gain of 100,000.
Once the audio signal has been processed into a PWM signal, that is how a class D amplifier produces gain, and only one stage is needed. Of course there is probably an analog amplifier to get the signal up to the level needed to produce the PWM.
michan
Feb 21, 2015
22
Thankyou, that helps a lot! I didn't realise it was using the same sort of gain mechanism as smps.
