How is coating wear on ESD tweezers typically assessed in production environments?
EdwardShone
Jun 25, 2026
I’ve been working with ESD protection practices in electronics manufacturing environments, particularly around static control programs, EPA setup, and tool selection for handling sensitive assemblies.
Recently, I started evaluating a pair of ESD-safe tweezers in a practical handling setup, and noticed that the anti-static coating has begun to show minor wear in the form of scratches and small chips, exposing the underlying metal in some areas.
From an ESD control perspective, I’m interested in how this is generally treated in industry practice:
  • In real manufacturing or rework environments, how critical is localized coating degradation on ESD hand tools like tweezers?
  • Does this level of wear typically have any measurable impact on surface resistance or charge dissipation performance in practice?
  • Or is tool effectiveness primarily governed by system-level controls (grounding, wrist straps, EPA compliance), making minor coating damage more of a maintenance/inspection issue rather than a functional failure?
In many production environments I’ve seen, ESD tool condition is periodically audited, but the acceptance criteria for wear on small hand tools doesn’t always seem clearly defined.
crutschow
May 7, 2021
986
What is the purpose of this "anti-static" coating on the tweezers since they are made of conductive metal?
Does the lack of it affect the electrical conduction of the tweezers to ground to perform the desired protection?
shrtrnd
Jan 15, 2010
3,903
Edward, Before I retired, we used a specialized spray-on ESD coating (that I don't remember the mfgr of), which rehabilitated the
effectiveness of ESD protection. The spray was commercially available.
crutschow, ESD coatings are to isolate the person handling the tweezers from the ESD sensitive devices.
14,280
Imho both of you are partly right: When you look up ESD coating you'll find that it is conductive, but at a comparatively high resistance. It allows static electricity to dissipate while limiting the discharge current.
Bare metal would not offer the desired resistance leading to high peak currents in case of a static discharge event.
Fully isolating material would not allow drainage of the excess charge which is required to equalize the potentials on the persona and the object the person is handling.
Its the same reason why e.g. antistatic mats are not directly grounded but via a 1 MΩ resistor.
So returning to @EdwardShone's question: a possible acceptance criterion might be a resistamce of approx. 1 MΩ between the ti of the tool and the handle, although this is pure guesswork on my side. If it's a critical parameter warranting periodic audition, I'd expect this parameter, its tolerances as well as audition intervals to be defined in the manual of the tool.
skylerbaggins
Aug 24, 2025
3
  • Or is tool effectiveness primarily governed by system-level controls (grounding, wrist straps, EPA compliance), making minor coating FNF damage more of a maintenance/inspection issue rather than a functional failure?
Minor coating wear is usually a maintenance issue, not an immediate failure. Most facilities replace ESD tweezers only if they fail resistance testing, develop burrs, or no longer meet ESD requirements.
