how many amps output
14,485
hi John
Not sure what these have to do with your strings of LEDS ???
you have linked to a PIR motion detector
Did you were the data given ?
Item Introduction:
•The sensitivity and holding time can be adjusted
•Working Voltage Range: DC 4.5V- 20V
•Current drain:<60uA
•Voltage Output: High/Low level signal:3.3V TTL output
•Detection distance: 3--7M(can be adjusted)
•Detection range: <140°
•Delay time: 5-200S(can be adjusted, default 5s +-3%)
•Blockade time: 2.5 S (default)
•Trigger: L: Non-repeatable trigger? H: Repeat Trigger (default)
•Trigger Method: L unrepeatable trigger / H repeatable trigger
•Work temperature:-20-+80°C
see the hilited line .... these supply a TTL output to feed in to Logic IC's
You are not going to control LED strings directly from these
What are you trying to achieve ??
conntaxman
Jun 17, 2011
89
hi John
Item Introduction:
Hi Dave, I just read about or now know that i cant just use these to turn on some leds. I thought that these had like a relay in them to turn on stuff.But i found a small cir. for them.
The cir is only about 6 parts so I'll have to build that to go alone with it.
Darn, i thought i could just use the pir sensor by itself.
Tks for the reply though
John
