How much Electronics Knowledge
Phil
Hi all,
I have been a computer programmer for the past 16 years of my life.
Mostly, I have done database type of work. I am now working as an
automation engineer designing PLC ladder logic applications, firmware
for the PIC microcontrollers, and HMI/SCADA applications.
Here is my question. Even though I have been doing electronics
programming for the past 5 years, I don't know a whole lot about
electronics. I basically only know atomic-theory and how to read/write
schematics and datasheets. How much do I really need to know,
theoretically, to be able to go to another company doing firmware? I do
have a degree but it is Computer Network Administration. Should I
concentrate my efforts in one field, thereby "pigeon-holing" myself, or
should I concentrate on a more "general" knowledge. I am no stranger to
doing research and very much enjoy it. However, I do not want to really
be a design engineer so to speak.
Any help, advice would be greatly appreciated!
Phil
Bob Eldred
Phil said:
Hi all,
Phil
It kind of depends on what jobs and opportunities are available in your
field. It sounds like you have already wandered away from your original
field of IT or computer admin. towards microprocessor programming. Needless
to say you don't need to know electronics to do either. However, the closer
you are to the circuitry as you are working with PICs the more you may be
expected to know about the underlying electronics. I feel that a generalist
has more opportunities than a specialist but the specialist may get the
better job if that job is available. A generalist can do anything even sweep
the floor if needed and therfore will probably keep a job when his work is
shipped to India. The more you know the better and the more chances you have
of finding work you can do, especially the way thing are changing these
days. On the other hand, becoming a degreed engineer is a long road to hoe
and may not pay off given the way things are changing. If I were you I would
try to learn some electronics so I could converse intelligently about how
thw PIC's an other circuits are hooked up but I probably would not go all
the way into Engineering.
K
Kitchen Man
Hi all,
I agree with Bob. (I misread your post at first, thought you said you
"really do want" to be a design engineer, in which case an EE is
essential.) Hang around with the firmware people at the place you want
to go, if you know them. You're already doing firmware and logic
programming, so you may already meet their qualifications. If not, you
can find out what they want.
Phil
Thanks to both of you for your suggestions. I was originally hired at
my current company to do the VB programming to communicate with PLCs in
projects that currently existed. However, my supervisor taught me a lot
about PLCs and PICs. Since he left, I have been maintaining old
firmware and creating new firmware. The programming is done mostly in
Assembly and Ladder Logic, which is the easy part.
I do appreciate the comments and will continue to learn electronics,
taking a more "generalist" approach.
