How much voltage and current can I power 5 white leds from a 9 volt battery?
awsomecp173
Mar 20, 2013
3
14,312
No 1: Please dont shout (use standard text style).
No 2: The voltage is, of course, 9V. The current you can draw from a typical 9V battery should be less than 500mA.
The typical capacity of a 9V block is around 500mAh. If you drain xmA of current, the battery will last approximately 500mAh/xmA. Note that the voltage will drop when the end of life is nearing (battery nearly drained).
Should you draw more than ~500mA from such a battery, you'll have to take into account the internal voltage drop of the battery which is due to the limited current generating capability of the battery's chemistry.
