How to add a mute system to an OpAmp
Shahriar
Mar 18, 2004
451
Hi
I have an OpAMp (NE5532) which is driving a Headphone.
I want to add a Mute System to this circuit.
How is it possible whether it has a Dual Supply or single Supply. (If it differs)
ThanX in advance
Sahriar
Shahriar
Mar 18, 2004
451
Hi
These two schematics are similar to the Ones I mean.
One is a Single Supply Amp and the other is a double supply.
ThanX in advance
Shahriar
Mute.zip
  • Mute.zip
windoze killa
Mar 4, 2006
136
I think the easiest method would be a switch on the O/P. just open cct the O/P
audioguru2
Apr 6, 2004
12,026
I muted the background music in a huge intercom system with a series resistor and a jFET to ground. Half of the input signal was fed to the gate of the JFET for very low distortion and the muting was made with a ramp for fading the music down then fading back up to avoid clicks.
Shahriar
Mar 18, 2004
451
Dear windoze killa
Can you write the full Dictation of CCT? I don't know what does it mean.
Dear Audioguru
Fading with a ramp was very  tricky. But I didn't understood where you put that Resistor anf FET?  ::)  ::) to mute the system
ThanX
Shahriar
windoze killa
Mar 4, 2006
136
Shahriar said:
Dear windoze killa
Sorry. CCT is just and abreviation for circuit.
Shahriar
Mar 18, 2004
451
Dear windoze killa
Thank you very much, Strange Abbreviation  :)
Dear Audioguru
I Had the same oponion to mute the signal in the same manner as you said, Of course with a BJT. I thought if the signal has a DC (i.e. 3V) then it works but when there is no DC I didn't have any oponion for Negative Cycles of Signal. Because in this condition, the Base-Collector Junction would go in Forward bias.
what would happen with a FET?
2- what I tested yesterday, In the Non-Inverting PAiA ciruit I attached, I put a NPN Transistor Between the 100k Resistor (R11) on the Noninverting pin of IC1:B and GND. When the Transistor was ON everything would work fine, when it goes Off, The Output would saturates gradually, but I didn't test it with a Sound Signal to see if It affect quality in Normal Condition.
What do you think?
ThanX
Shahriar
audioguru2
Apr 6, 2004
12,026
Hi Shahriar,
The ordinary transistor has very reduced current gain when the signal ihas reversed polarity so the muting will be a little rectified.
Use a jFET like I said. It is a voltage-variable resistor and with the low level from the mic it will have low distortion even if you ramp the muting.
Wien bridge oscillators frequently use a jFET for amplitude control.
Shahriar
Mar 18, 2004
451
Dear Audioguru
Thank you very much...
But do you have any oponion about The Transistor in the noninverting Pin.
Have I explained it clear?
ThanX
Shahriar
audioguru2
Apr 6, 2004
12,026
Shahriar said:
Dear Audioguru
Like I said, an ordinary transistor would probably rectify the signal when it is turned on which would make low-level distortion. JFETs have been used for muting frequently.
