mike
- Jan 1, 1970
- 0
budgie said:BZZZZZTT! Wrong. As anyone who has worked on the design of CC/CV chargers
would know, when transition from CC to CV occurs, the cell is about 60% charged.
Also, the current does not "drop to zero" at transition - rather it starts an
almost exponential decay from the CC value. Typically this will take 2 hours or
more to drop to 10% of the CC value.
OK, sanity check.
You are not gonna pack a windmill on your bicycle. File that under,
"sounded like a good idea at the time."
You are not gonna build fixtures to hold all your batteries for external
charging poking out all over your bike rugged enough to hang onto the
batteries when you ride down that mountain trail. File that the same place.
Get yourself 10 high capacity AA NiMH cells and pack them into a thing
that snaps on like a tire pump. Hook them up to your bike generator and
charge the crap out of them. Use a thermal cutout in series that opens
when they start to get warm. Do some experiments using your typical
riding speed to see if you are applying way too much charge current and
add a resistor as required.
Don't worry too much about properly charging the NiMH. Just let the
overtemp switch take care of it. Might want an indicator so you can
manually switch 'em off. Plan on throwing them out when your trip is done.
At night, snap off the cell pack and use adapters with fixed voltage
outpts to connect to your devices for charging. Let the device manage
its own charge/discharge. You can charge multiple devices
simultaneously until you run out of energy.
Not the most efficient way, but at least it's practical.
mike
Wanted, Serial cable for Dell Axim X5 PDA.
Return address is VALID but some sites block emails
with links. Delete this sig when replying.
FS 500MHz Tek DSOscilloscope TDS540 Make Offer
Bunch of stuff For Sale and Wanted at the link below.
MAKE THE OBVIOUS CHANGES TO THE LINK
ht<removethis>tp://www.geocities.com/SiliconValley/Monitor/4710/
