how to bypass dremel tool internal variable speed control?
I'm on my second electronic variable speed control inside my Dremel
model 395 tool. This one just crapped out with the same temperamental
symptoms as the last one. I need to use the tool tomorrow night, and
would like to bypass the internal variable speed circuitry to simplify
it; maybe buy an external control later.
There aren't any wiring diagrams I could find on the Dremel site. I'm
thinking if I had one for the model 275 tool (single speed) and the
395 (electronic variable speed), I might be able to make the 395 into
a 275 by just jumpering some wires. I'll probaqbly need to at least
retain the variable speed assembly, since the brushes fit into it.
Can anyone help?
Jamie
Can anyone help?
Obvious, it's junk! Buy a new model dremel.
or better yet, by one of those no name brands
like I did, looks like it's made in the same place
but cost much less!
$29.00 for a complete set of cutters, stones with
variable speed unit.
I think it was "All Trade" or "TradeAll" or something like that.
Claude Desjardins
Can anyone help?
Hi
Just take it apart, I'm pretty sure it's just a "potentiometer"
(variable resistor) so it would only have 3 leads, one from the external
wire to the pot., one from the pot to the motor, and one from the other
external wire to the other lead of the motor.
Cut things off, plug the external leads directly to the motor.
You can make yourself something that would do the same with a variable
light controller (those you have to control your house lights) Get one
of these, one wall plug unit and one extension cord.
PWR IN (1) to VARIABLE (1)
VARIABLE (2) to PWR OUT (1)
PWR IN (2) to PWR OUT (2)
it would be an awesome idea to tape everything together to cover the
connections once you're done so you don't get shocked everytime you want
to slow it down or speed it up :)
Have fun
(PS I also have one of the new Dremel units and it smokes too ... Uh.)
lj_robins
Can anyone help?
I'm not positive, but I would think if you just soldered a wire around
the speed control it would run at full speed, I could be wrong though.
-Landon
Unfortuantely it doesn't seem that simple. The speed control has what
looks like a some kind of semiconductor/IC (3 leads), a diode, and
maybe a fixed resistor in addition to the slide pot. I don't know if
they're doing pulse width modulation or what.
Trevor Jones
Can anyone help?
If you cannot figure that out by looking, you probably should not be
dicking around with it.
The last fried speed control in a chinese one I bought, took a buck's
worth of a new triac to fix.
Cheers
Trevor Jones
Claude Desjardins
I doubt they have put a stepper motor in there, they wouldn't sell for
20$ each! -- You still should only have two leads coming out of the
motor. Confirm?
Claude Desjardins
motor. Confirm?
Btw you said there was a IC ... how many pins does it has, can u give
out the ID (in case it's a bridge or something so your motor would be DC
(Uhm?!) and wouldnt be a great idea to plug it right into a wall outlet!
James Sweet
Of course it's not gonna be a pot, it would have to be far too big and burn
up a lot of power. Instead they use what is essentially a light dimmer. The
semiconductor you see is a triac, the diode is a diac to trigger it, if you
just jumper together the right two pins on the triac, the motor will be
forced on.
N
Ninja
It sounds like you're describing a light dimmer circuit. See
http://www.aaroncake.net/circuits/dimmer.asp for an example of a typical
circuit. If your circuit is like that one, running a jumper wire across TR1
will get you going at full speed. I presume you can figure out which two of
the three thyrister leads. And you do know your safety rules for working
with mains powered equipment, right?
W
William Noble
the speed control is a triac based phase control, the same as a light
dimmer - typically it has two wires, just short the two wires together and
the dremel will run full speed all the time.
by the way, typical failure is just noisy pot, try cleaning carbon track
K
Kristian Ukkonen
Mine had a smd triac BT134W which was faulty.
I replaced it (easy!!) with a new one, and
the dremel has worked years after that. The
triac costs about 1 usd.. The parts are on a
white ceramic circuitboard.
Kristian Ukkonen.
Arfa Daily
burn up a lot of power. Instead they use what is essentially a light
dimmer. The semiconductor you see is a triac, the diode is a diac to
trigger it, if you just jumper together the right two pins on the triac,
the motor will be forced on.
Don' it just hurt to the core, James ... ? !!! ;~)
Arfa
B Fuhrmann
hillpc wrote ...
it; maybe buy an external control later. . . .
Can anyone help?
This is one of those cases where "If you don't know already, you probably
shouldn't be doing the job".
The wiring should be simple enough to do it by inspection. If it isn't, you
really need the schematic and the ability to understand it.
Unlike the other poster, I really doubt that the motor speed control is just
a pot.
Jamie
That's a simple phase control SCR circuit.
the diode is a DIAC.. etc..
if it's not firing, I would check the pot and
resistor.
Michael A. Terrell
motor. Confirm?
Every Dremel tool I've had apart used a universal motor, and the
speed control was a simple dimmer circuit. This one might be PWM, and
run the motor on DC.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
Jamie
Most of the cordless drills these days use PWM power FeT drivers.
I modified a cordless drill with a mini PIC and Bridge to
perform regulated torque control, auto reverse and then forward
again until maximum torque was no longer peaking. Did this so that
the drill would have a TAP mode in it. I stuck a mini pot on the back
side of the handle to set the torque level.
if his dremel is also cordless, It may also be using it a PWM?
who knows. how ever, with the part count, I'm guessing he's using a
corded unit with a phase control.
Michael A. Terrell
None of those I've seen used an IC in the speed control. Also, he
didn't mention a filter capacitor, so id may be a simple dimmer
circuit. It's hard to tell from such a vague description. Part numbers
would have been a big help.
BTW, have you seen the small DC powered clone at Harbor Freight? It
runs on 12 VDC, and comes with an AC adapter. I was thinking about
using one (or more, with different sized drills) with a homebrew CNC
machine to drill PC boards.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
Jamie
Hmm, No, I haven't checked into Harbor Freight in some time how ever, I
think you'll find that a lot of named brand tools we know are now being
made by the same people that make the no-name brands from China.
For example, I have a rotary tool that in all respects is a dremal.
bu t the name isn't of course.
As far as drills with PWM, the Craftsman 1/2 drive chuck cordless uses
PWM driver board which is mounted as part of the trigger. the speed pot
slider is on the board. It employs an IC chip with a logic level Power Fet.
We have some electric real movers that are still being modified by the
manufacturer because they can't seem to get one to last any longer than
2 months in our shop. First they had drive problems where it wouldn't
start half the time. This was an elaborate board with a micro driving
what looked like a Mosfet H-bridge.
Any ways, we sent them back, the next set that came our way, they
modified with the speed control in the handle of the unit. All they
did was employ a speed control trigger slide switch from some existing
cordless drill system.
Those were very simply units, a single Power Fet with a 555 timer
driving it. Not sure if it was variable freq pulsed or PWM? Anyways,
those have a switch in the slide that initially connected the + batt
lead to the Vcc and Drain of the Powerfet. the Minimum speed was too
much on initial start. Those would burned them self's up in the switch.!
oh well, so much for engineering.
