How to Charge Batteries in Parallel or Series?
N
Neil P
For the 6v golf cart type, do you charge each one individually?
And for parallel configuration, lets say we have 2 deep cycle 115 Ah
batteries in parallel, would a 2/20 automatic deep cycle charger capable
of charging both at the same time?
Thanks for your inputs,
Neil
BugHunter
Neil
You can charge any number of batteries at the same some, with the correct
voltage charger.
For example Two 6v golf cart batteries hooked up in series can be charged
with a 12v charger. Four 6v batteries wired in series-parallel to make a 12v
bank could also be charged with the same 12v nominal charger.
The larger the rating of the charger in amps, the faster the batteries will
charge. Well, within limits. An undersized charger will take lots of time.
Two large a charger (if not throttled back) could cook the battery. you want
to have a reasonable match between the charging amps that you produce and
the capacity of the battery bank to accept that charge.
For off grid applications with large battery banks, you typically would try
and get the biggest charger you can to minimize run time of generators which
are noisy.
I have used a 10 amp charger to charge 4 220 amp-hour 6v batteries. It takes
forever. A 35 amp charger does it a whole lot faster. I would not be afraid
to try a 170 amp charger.
Think of your battery bank as a water tank (both have storage capacity). A
more powerful pump can fill you tank faster. But, the hose connections
(voltage) still need to match between the tank and pump.
A 2/20 (amp) charger would be adequate for 230amp hour battery bank as long
as it was voltage matched to the bank configuration.
clare @ snyder.on .ca
voltage charger.
are noisy.
Charging batteries in parallel CAN cause problems if the batteries are
not matched. That's why it is better to use 2 honking big 6 volt golf
cart batrteries in series than 2 12 volt batteries of the same
physical size in parallel.
A battery is multiple cells in series, so putting multiple batteries
in series still gives you a battery. Multiple batteries in parallel is
still multiple batteries.
N
Neil P
i am deciding: 2 6v golf cart in series or 2 deep cycle (identical) in parallel
i will be charging from grid power, so i am thinking that a 2/20 would be
sufficient for either 2 6 volts or 2 12 volts with 115 ah each. sounds good?
thanks again,
neil
W
William P.N. Smith
As Clare said, 2 golf cart batteries in series will give you better
results, and more even charging (charge current will always be exactly
the samein both batteries).
Be aware that an undersized multi-stage charger may never reach the
'current dropped below some threshold, so I should switch to a lower
voltage' state. I saw this happen recently with a 6V golf cart
battery and an Accumate charger from
http://www.mayberrys.com/honda/generator/html/accumate.htm and it
ended up boiling the battery without switching to the 'float' mode.
A Trojan T-105 is the 'standard' for golfcart batteries, and it's a
couple hundred amp-hours. A 20-amp taper charger isn't bad if you
don't mind 24 hours or more for a charge, and 2 amps is probably a bit
much for a float charge. Why not get a real multi-stage charger from
(say) Trace/Xantrex, or if you haven't already bought the inverter, an
inverter/charger from them...
N
Neil P
dont mind 15-24 hrs to recharge, just want to have a good setup where i recharge at
the right amps and float as well without any "cooking"
i have the inverter already, i am trying to locate a suitable charger locally. what
amps should a float charge be at?
neil
W
William P.N. Smith
Well, it probably shouldn't be "amps" that you float charge at, but
volts. While constant current float charging has some advantages,
most 2 or 3 stage chargers end up float charging at a fixed voltage.
If you have an automotive battery charger with a "2-amp" and a
"20-amp" switch, that's not at all suitable for unattended battery
charging, and not very good for attended battery charging, because it
requires close attention to battery current and voltage, and if you
get distracted and walk away, you'll boil your batteries dry in short
order.
Look on the Xantrex WWWebsite for 2 and three stage chargers.
Basically they are a current-limited high-voltage charger that waits
for the current to get below a certain threshold, when it switches to
a lower voltage for float charging.
A battery temperature probe is best, as it'll tweak the float voltage
setpoint to exactly match your battery. The size of the charger ought
to be compatable with the capacity of the battery (within some range)
to avoid the "wait till the current drops below some threshold" mode
from getting stuck or easily confused.
N
Neil P
Thanks for the ideas, however at this time I am using 1000 watt inverted bought at
Costco (modified sine) for 69.99. I am looking for a low cost backup to grid power for
max of 2-3 hrs and max of 200 watts. I am on my way with the battery and saw automatic
chargers that list 2/20 and was wondering if the 2 am is too much to trickle charge.
Schummer (sp) sells the charger and they have a 1.5 amp trickle charger that turns on/off
to maintain the battery. Am wondering if this is safe for my operation?
http://store.yahoo.com/rodi/acse-1-12s.html
Neil
W
William P.N. Smith
I'm not sure what they mean by 2/20, can you clarify that 'spec' for
us?
That one looks OK, though only for float charging of course, and I
can't say much about the manufacturer. On the other tentacle, the
Xantex TrueCharge 20+ seems to go for around $250, which will buy you
a lot of batteries... 8*)
N
Neil P
2/20 on this charger that is automatic says: it will start out at 20 amps and trickle down to
2 amps to float and turn on/off to maintain the battery.
I have recalculated my use for power outage, and all I need is 11amps/hr. I have my eye on a
12V 115 amp/hr deep cycle battery. 50% of that conservatively is say: 50 a/hr. At 11 amp/hr
need, I can run for approx.: 4 hrs and only discharge the battery to 50% or more.
Based on this would a 10 amp charger be fine and the 1.5 amp float charger to maintain the
battery year round?
neil
W
William P.N. Smith
Well, if it really does turn off and is an automatic battery charger,
then it should work just fine.
You are having a little confusion with your units, amp-hours is a
quantity, and amps is a rate of flow, but if I understand that you
only need 11 amps for 4 hours then that should be fine.
battery year round?
Well, you have to decide what you want your recharge time to be (if
this is for the occasional blackout then a week to recharge won't
bother you). Is the 10 amp charger automatic? [I really wouldn't
reccomend a non-automatic charger, as you _will_ forget and leave it
on too long.]
The 1.5-amp float charger looks OK, but if they 2/20 charger
referenced above is properly sized for your battery and really does
turn off when the battery is charged, then it should be OK. Check the
voltage and electrolyte level regularly until you know what your
maintenance interval should be.
Bob Adkins
This would not apply to low a current charge, such as a small PV array,
correct? Seems that the batteries would have plenty of time to "level"
themselves.
Bob Adkins
battery year round?
This sounds perfect for a 115 AH battery.
If you don't discharge it to 50% more than 2-3 times a year, it should last
a long time.
N
Neil P
i will have a calibrated digital voltmeter (calibrated at work, EE company) that will monitor my
battery. My battery selection is now a 12v 115 amp/hr deep cycle battery. My needs are tops 11
amps.
Somewhere i read there a c/10 rating for the battery, in my case a 10 amp charger should be fine
with a 2 amp floater? There is a 2/10 automatic deep cycle charger i see available locally.
Thanks again, much appreciated.
Neil
battery year round?
on too long.]
themselves.
More critical in some ways. If you have one bad battery (shorted cell,
or partially shorted cell) it will drain the good battery as fast or
faster than the PV can recharge - so your batteries are always low.
With series connection and a shorted cell, the other cells will be
slightly overcharged, and overall pack voltage will be low.
