How to connect two sirens
SixDoubleO
I have a DSC 832 and two sirens. A DSC SD15W (inside siren) and a DSC
SD30W (outside siren). Can I connect these in series to the bell
outputs? Based on the power output of the DSC 832, it should be able to
power the two of em. Just wondering if I'd throw off the impedance for
supervision by putting them in series. If I put them in parallel, it
seems I'd lose supervision.
Suggestions?
G. Morgan
alt.security.alarms
Only if you home-ran both wires to the control. Run one wire to the
first siren, then run a wire from siren one to siren two, put the EOL
at siren two.
-Graham
Remove the 'snails' from my email
SixDoubleO
I currently don't use an EOL on my bell circuit. I think just the
impedance of the siren itself provides the needed resistance.
So you are saying to wire the two sirens in parallel, with a EOL between
the + and - of the last siren? Do I need to do anything to the panel
programming to tell it I have an EOL?
Jim Rojas
Some sirens actually will create a "low wail" feedback noise, then you would
have to use the EOL to eliminate the feedback.
Jim Rojas
G. Morgan
alt.security.alarms
You're right. I just re-read the manual. The 1K resistor is only
used if no devices are connected to the bell output.
I see what you mean now. :)
NO- disregard what I wrote earlier.
In order to supervise both, they would indeed have to be in series.
Most panels DO require a resistor at the EOL, but the 5015 apparently
uses the impedance of the sirens. Sorry for the confusion, DSC panels
are not my specialty.
I am wondering now though..... what is the current range (low/high)
that is acceptable before the panel detects an open or short?
One more thing.. The bell output only supplies 700ma when the system
is running on back-up battery. You will exceed this with the SD30W
connected, it alone draws 1.1A.
-Graham
Mark Leuck
G. Morgan said:
alt.security.alarms
Wrong, the panel always sends voltage through the circuit to supervise it,
without the resistor you might get a low level siren sound
G. Morgan
alt.security.alarms
I knew that....
So that begs the question... What is the ideal impedance for the
circuit? And what are the lower and upper limits before it goes into
trouble?
-Graham
F
Frank Olson
G. Morgan said:
alt.security.alarms
Putting them in series won't be a problem. They're rated for 6 - 12 VDC.
You *will* maintain supervision of the total circuit if you do and if some
perp does short the wires (when he cuts them) at one siren, the other will
still surprise him...
The sirens he's talking about have built-in DC drivers. "Impedance" doesn't
figure.
The system's perfectly capable of supplying the necessary power for a
*short* time. You can draw up to 3 amps from the bell output for short
periods. Your battery has to be attached and in good shape. Check out page
6 of the manual and don't make me "bitch slap" you like I had to Bass. :))
Frank Olson
http://www.yoursecuritysource.com
Free listings for qualified dealers and industry professionals
You can read the ASA FAQ at
http://www.yoursecuritysource.com/asafaq.htm
For what it's worth....
When testing the system (ie, no siren.) I use 1000ohm resistor. The
system reports no trouble.
With ONLY the SD15W connected (and no EOL) the system reports no
trouble. Resistance across the SD15W (and 50ft of 18/2) is 1189ohm.
I'm going to try hooking the SD30W in series and see what the resistance
measures out to.
I'm surprised this isn't documented as an inside 15W/outside 30W is a
fairly common setup.
Thanks Frank. That somewhat confirms what my suspicion was. If I ever
get a 5204, I'll drive the SD30W off that. For now, I'll just run it
off the panel and deal with the possibility of a shorter yelp-session.
(stepping out of the way of bitch-slapping)
Mark Leuck
Say again?
JW
I don't get it...why is everyone talking about impedance? Sirens work off a
12VDC input don't they?
mikey
12vdc sirens are just speakers with the driver built in. Some panels have
the drivers on the control board so you just use speakers. I think they mean
resistance in this thread. As long as there's some current flowing, I think
the supervisor is happy.
F
Frank Olson
Mark Leuck said:
message
Say again?
Series connection on two sirens. You short the leads to one and the other
will still function. If there's no direct short, the circuit will open and
the panel will go into "trouble".
alarman
Shhhh!!
Yes. Some are confusing sirens with speakers. It's comical to watch.
js
G. Morgan
alt.security.alarms
I think they mean
Yes, impedance would apply to speakers where resistance would apply to
the siren driver. I got the two jumbled in another post.
Does anyone have a 5015 lying around to test? I'd be interested to
see the range of resistance the output likes. It could easily be
tested with a potentiometer.
-Graham
Mark Leuck
I do but you can't have it
Why wouldn't you just test a 5010 or 1555? Should be the same
G. Morgan
alt.security.alarms
I didn't want it, I wanted you to do the test.
-Graham
Mark Leuck
I just did the test, its +/- 200 ohms, now please scroll to the bottom of
this reply
G. Morgan said:
alt.security.alarms
-Graham
I didn't really do the test
G. Morgan
alt.security.alarms
I know you didn't. :)
If you had the appropriate answer would have been more like "lower
range {x} ohms and upper range {y} ohms".
Maybe someone kinder than you will do the test and report the results
for the good of ASA and mankind in general.
-Graham
